Old 11-18-2009, 01:37 PM   #21 (permalink)
Aero Sol - '93 Del Sol GSR
90 day: 40.31 mpg (US)
UPDATES: Tinkering, refining...
BEFORE:
AFTER:
At this rate, im NEVER going to finish this car
Old 11-19-2009, 07:51 PM   #22 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I think your rear section on your skirts is going to be too steep for airflow to remain attached. It's a minimal wake area, but just thought I'd throw that out there for you.
Old 11-20-2009, 12:26 PM   #23 (permalink)
Yeah, I noticed that after I finished making it, unfortunately there is no mounting point further back in the bumper. So I was thinking about extending the wheel skirt to wrap around the bumper like this:
And then secure the rear section with clear packing tape i guess
Do you think this would help?
Old 11-20-2009, 12:39 PM   #24 (permalink)
Steve - '92 Festiva
No, no, and no...
I was actually thinking that since it's aluminum bar stock, you could just make a triangular piece and rivet/weld it to the existing rear angle so that it would naturally overlap the bumper. A neoprene gasket (old door seal) would keep water/dirt from getting in there, if you were so concerned. That would make it possible to sweep the angle right back to the tail end of the bumper!
The Following User Says Thank You to Christ For This Useful Post:
jedi_sol (12-09-2009)
Old 12-09-2009, 06:05 PM   #25 (permalink)
Side mirrors delete: How To on Del Sol
Then from the bottom, pull out the cover until it pops out. Then LIFT UP the cover, while at the same time, thread the door handle through the door. Unplug the plugs for the power windows. You should be left with this.
Then think of a way to replace the mirrors, here is what I came up with. (It's supposed to say "METAL")
Old 12-09-2009, 06:21 PM   #26 (permalink)
discovery's Avatar
Very Cool, i realy like the way you put tape or something on the headlights. Do you plan to remove any wipers or just keep one? I like it.
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
Old 12-09-2009, 06:33 PM   #27 (permalink)
Thanks. Yeah, it's just clear plastic packing tape. I saw another Del Sol owner on here do the same thing, except for the entire car. So i figured i'd give it a try (not the whole car though). Not actually sure if its giving me any positive FE results because it seems such a minor thing to do. But i figured every little bit will help.
I plan on keeping the wipers, I made a cover for them though (not pictured). I did tuft testing with it and it didn't seem to make any difference with the airflow.
Old 12-09-2009, 07:06 PM   #28 (permalink)
Steve - '92 Festiva
Some shrink wrap will likely come out cleaner on the headlights than the tape does. All those wrinkles in the tape make it look like a bad patch job on the headlights, like my tail light looks right now. (It's held in with duct tape.)
Old 12-09-2009, 09:45 PM   #29 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
power stearing delete should not be that hard to do if you find junked 5th gen civic DX
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 12-10-2009, 10:27 AM   #30 (permalink)
pgfpro's Avatar
Looks good!!! That really clean up the looks of the car too.
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 02:30 AM
My new car. Honda Del Sol pgfpro Introductions 4 08-29-2009 01:28 AM
1993 Honda Del Sol conversion delsolectric Fossil Fuel Free 5 06-09-2009 12:18 PM
Regearing my Honda (1994 Del Sol VTEC) Shortie771 EcoModding Central 79 06-05-2009 01:04 PM
Project: Del Sol Kammback Trial Mockup jedi_sol Aerodynamics 19 04-14-2009 10:52 AM
