Old 07-07-2008, 11:18 PM   #51 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I started work on fabrication tonight (of the "good", permanent version).
I'm planning to glass directly over the upper cardboard panel because it's exactly the right shape already.
I removed the two "side" panels though - they were less than great (corrugated stuff doesn't do compound curves nicely). I recessed the panels about an inch or so to serve as a backing, and will fill the area with Great Stuff expanding foam, then shape it and glass it with the top section.
(The cavity that will be filled with foam. The tin foil is the "release agent" from the hatchback surface.)
I have it on good authority the foam is fairly easy to work. I filled one of the sides about an hour ago - hopefully it cures hard, because even though it's tack free, it seems pretty squishy.
I would say this, so far: based on the amount of time I think it'll take to do foam/fiberglass construction, I think if you know your plastic and can get a proper sheet of ABS (or whatever is the right type to heat form into compound curves) , that would be the way to go.
Once the upper surface is glassed, I'll remove it from the car and add foam to the center section & glass the entire bottom, to make a sandwich.
Old 07-07-2008, 11:27 PM   #52 (permalink)
Originally Posted by .Cd View Post
Both you and I have a rounded tail end to our cars.
I'd guess that they are rounded for a reason, but as we know, a sharp edge is usually better than a rounded end.
I'm not sure you can get any useful info from doing a tuft test comparison of the two styles. A sharp cutoff of a proper taper will simply show the tufts streaming straight back before the cut. A radiused cut off will show some turbulence after the separation point on the curve.
I never did get a good answer to "which is better" after that long thread at GS. It's something I'd like to talk to a pro aerodynamicist about if I ever meet one.
Old 07-07-2008, 11:43 PM   #53 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Why not fire off an e-mail to one of the guys at the A-2 windtunnel ?
They seem like nice folks, and while they wouldn't want to share all of their secrets, they could also stand to gain some new business by advertising on this site.
Dave@aerodynwindtunnel.com
Office: 704.799.1001
Fax: 704.799.1112
Wouldn't it be cool if we could invite them to this site and ask their advice ?
( Since you head this site, you have a lot more 'pull' than i do. )
In the mean time, I'll try to call the Texas Tech windtunnel guys. I spoke with one of the guys a while back and he was cool about it, but they are really too busy to answer questions from any of us.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 07-07-2008, 11:49 PM   #54 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Any raised edge that's not parallel to the flow will trip the air. Angled raised edges will spawn vortices.
My mistake. I was thinking of the fences on supersonic jets.
The MIG 15 had fences on its wings.
Old 07-08-2008, 11:25 AM   #55 (permalink)
Well, the foam did cure stiffer than when I last checked last night, but it's still somewhat spongy. I was a little disappointed. Not ideal, but workable. Also, the expansion caused the foam to lift the "leading" edges where it meets the hatchback (the "C" pillar area).
I was able to carve/shape the contours I wanted using a bread knife for the roughing in, a hand held hacksaw blade used as a rasp for finer shaping, and some coarse sandpaper on a sanding block. But it's going to take a lot of "finishing" work with body filler & spot compound to get it smooth & looking nice after the glass is laid over top.
I'll do the other side this evening, and post up some pics. I'll lay up the first layer of fiberglass tomorrow.
Old 07-08-2008, 11:30 AM   #56 (permalink)
If this turns out well, I was thinking I could make a mold and produce copies for people, but shipping would be a problem! Not really practical.
Old 07-08-2008, 11:45 AM   #57 (permalink)
akcapeco's Avatar
V-strom 650 - '07 DL-650 V-strom
90 day: 55.03 mpg (US)
07 Focus ZXW - '07 Focus ZXW SE
90 day: 30.09 mpg (US)
freight shipping on something like that might not be too bad
Old 07-08-2008, 11:59 AM   #58 (permalink)
open or closed
Originally Posted by dcb View Post
So what is the verdict on open back or closed back?
Also, what is your time frame? I'm wondering if I'll have time to finish the auto CDA computing on the guino first. No biggie, but that is exactly the intended usage for it.
dcb,your's is a very good question and while I won't have the definitive answer,here's how I understand it.Both open and closed boat-tails, when properly configured,allow for a reduction in cross-sectional area of the car's body without flow separation.As the air is decelerating down the slope of the boatail(top and sides),it is regaining pressure.Following the "ideal" teardrop path,every 10% of additional tail length is good for about a 10% reduction in area,10% increase in pressure,and 10% decrease in drag,either open or closed.( It's not a linear relationship because of the curved wall of the ideal teardrop,versus a straight-walled cone).According to Ford,if there is a "back" to the tail,air separating at the truncation(chop-off), will round the corner of the back,and slam into the vertical surface,providing a minute degree of thrust.Chrysler calls it "bursting".I have no quanta to tell you the difference in performance between the two,however,if you want to split hairs,it looks like the closed boat-tail crawls away with the victory cup.
Old 07-08-2008, 12:14 PM   #59 (permalink)
Darin,it's great what you did with the image.It's exactly where I was going! My teardrop is long,although it's what's trotted out alot in fluids books.The 2.5:1 is supposed to be the absolute minimum for form drag and skin friction.The tail is 1.78 times the diameter of the drop.From the photos you can see smoke separating early on the Kamm K-Car and even the Insight.Why GM did the Impact/EV-1 the way they did may have been a styling concession and to improve rear vision.In plan-view,the EV-1 is beautiful,with body taper beginning midway on the doors.
Old 07-08-2008, 12:18 PM   #60 (permalink)
I think you're good to go with your red line!
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-making-permanent-metro-kammback-extension-3518.html
Posted By For Type Date
How To Get 99.7 Mpg From A Geo Metro This thread Refback Yesterday 02:20 PM
Ecomodder News, Videos, Reviews and Gossip - Jalopnik This thread Refback 01-18-2012 06:28 AM
100 mpg News, Videos, Reviews and Gossip - Jalopnik This thread Refback 12-01-2011 11:59 AM
Hypermiling stories - Jalopnik This thread Refback 10-09-2011 05:24 PM
Tuft testing a "Kammback" mockup - Geo Metro aerodynamics - YouTube This thread Refback 08-24-2011 01:35 AM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-14-2011 08:37 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-14-2011 02:02 PM
New car tech that saves on fuel - Sympatico.ca Autos This thread Refback 01-21-2011 01:18 AM
Wow A Best ever MPG! - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum This thread Refback 01-03-2011 02:30 PM
Kammback Creator to be Inducted into Automotive Hall of Fame | CarZilla This thread Refback 12-21-2010 03:32 AM
SerayaMotor.com • View topic - IIMS 2010-Ford Fiesta Review & TD This thread Refback 08-01-2010 11:24 PM
Four cylinders are for chumps - 100 miles-per-gallon in a Geo Metro — Autoblog Green This thread Refback 06-15-2010 01:18 PM
Autoblog Green — We Obsessively Cover The Green Scene This thread Refback 06-15-2010 01:03 PM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 06-14-2010 02:28 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 06-14-2010 02:02 PM
Donderdagavond caption contest: doe het met hout » Autoblog.nl This thread Refback 04-08-2010 04:12 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 11-27-2009 02:00 AM
Kamm Back - Overview : Kosmix This thread Refback 10-24-2009 10:39 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 08:04 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 02:21 AM
