Old 09-19-2010, 09:21 PM   #1 (permalink)
Want2BAHyperMiler
KCF3712's Avatar
PeytonsLimmo - '07 Kia Spectra EX
90 day: 40.55 mpg (US)
PeytonsVolMobile - '07 Chevy HHR LT1
Speedo reprograming
Does anyone know if you can reprogram the computer / speedometer to compensate for a tire size change?
Thanks in advance
KCF3712
Old 09-19-2010, 09:44 PM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
This might sound simple, look in the manual. If it is not there, try your favorite search engine.
I have heard of it being done, not sure you can do it.
Now if you had a ScanGauge, there is a setting for that.
The Following User Says Thank You to Weather Spotter For This Useful Post:
KCF3712 (09-20-2010)
Old 09-19-2010, 09:46 PM   #3 (permalink)
...beats walking...
...for GM products, there's an after-market "box" that can be connected in-line with the wheel Speed Sensor that allows you to 're-calibrate' the number of pulses per mile being sent to the ECU.
...unfortunately, I don't know of anything similar for a Kia.
The Following User Says Thank You to gone-ot For This Useful Post:
Honda VX intermittent speedo issue NachtRitter Off-Topic Tech 13 08-07-2010 09:21 PM
Speedo Accuracy with MPGuino :-( hummingbird Instrumentation 4 04-07-2010 12:26 AM
Mechanical speedo, possible? underitall OpenGauge / MPGuino FE computer 6 11-27-2009 04:56 PM
Speedo outta calibration? Mogal Instrumentation 10 05-09-2009 03:16 PM
Speedo LZR trebuchet03 Aerodynamics 1 04-17-2008 11:34 AM
