Old 01-16-2008, 08:36 PM   #1 (permalink)
Nomadic Chicken
WaxyChicken's Avatar
Regenerative Braking - how does it work?
I'm looking for a more detailed link on how Regenerative Breaking works.
I know they use generators at the wheels, but how do they engage/disengage them so that there isn't an extra energy load during driving?
Also, while i'm at it, some of the EV Cars I've seen on the news use more than one motor located at the wheels to reduce mechanical energy loss. How do they ensure that both motors turn at the same rate?
(EG: i've once had 2 exact same computers with cloned hard drives. one would boot up in 4 mins, the other would boot up in 2 mins even though they were "Exactly the same")
Thanks.
Old 01-16-2008, 08:59 PM   #2 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Physics and electronics help.
The car is going to keep trying to go in a straight line, thereby dictating that both hub motors will have to keep spinning at the same RPM. If one motor were to try to spin slower or faster the car would begin to deviate from it's trajectory, something it does not want to do.
Electronics may help with the acceleration side, controllers can keep track of a motors RPM, and would ensure that they are perfectly matched unless of course you're accelerating around a curve, in which case the motors won't be matched, mimicking the action of a differential in a traditional car.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 01-16-2008, 09:01 PM   #3 (permalink)
Nomadic Chicken
^ Thanks (in short english - onboard computers. )
Old 01-16-2008, 09:03 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Just use a throw switch like on an old bike generator.
Old 01-16-2008, 09:39 PM   #5 (permalink)
Nomadic Chicken
So basically a hydrolic or cable system that swings (engages) the generator against a wheel gear when the brake is pushed. Gotcha.
Old 01-17-2008, 01:58 AM   #6 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
No no - throw the electrical switch Unless the motor has a load on it (closed circuit + load) - it's not going to have any resistance (well, a tiny tiny tiny bit). No load (open circuit) - throw a switch to complete the circuit - and current will flow
That being said - cars like the Prius, for example, do not have motors at the wheel (in fact, most cars - EV/hybrid/etc. are like that due to the huge amount of unsprung weight that adds). Instead - it's just wherever the drive motor is...
The new Prius uses boost converters so they can have a lower pack voltage - this means they can regen brake at lower speeds....
GM-Allison's bolt-on hybrid transmission has the motors located inside the transmission itself and those handle the regen braking.
Challenge me, or correct me, but don't ask me to die quietly.
Old 01-17-2008, 02:17 AM   #7 (permalink)
Nomadic Chicken
Ahhhhhhhhhh.......... Thanks trebuchet
Old 01-19-2008, 12:03 AM   #8 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
As i understand it, the regen part is where it gets expensive. just a dc drive probably wouldn't cost more than 8 or 9 K$.
Old 01-19-2008, 12:44 AM   #9 (permalink)
Nomadic Chicken
but couldn't you use starter motors as regenerative motors?
(isn't that what makes a generator? running a motor to make the charge? would that
work? i wonder....)
Old 01-19-2008, 01:02 AM   #10 (permalink)
AndrewJ's Avatar
The tricky part about regen in EV's is the controller. More expensive controllers are needed to enable regen. Any motor will work to make regen happen, so long as you have the right controller.
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 09:29 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
News: GM's chairman - "small cars don't work in this country" MetroMPG General Efficiency Discussion 32 11-19-2008 07:50 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 01:21 AM
Request for 'work in progres' thread Daox Forum News & Feedback 4 12-23-2007 11:03 PM
