Old 01-08-2012, 04:35 AM   #21 (permalink)
kurzer's Avatar
Knut - '07 Prius
90 day: 50.9 mpg (US)
Santa - '00 Santamo
90 day: 29.07 mpg (US)
Originally Posted by TXwaterdog View Post
You can perhaps install a kill switch that only engages the alternator when you feel it's nessisary.
what about a little more practicable solution? a adjustable switch at the throttle, for WOT alternator disable. every time, you go for accel the car, the alt is go for a rest. if the car is coasting or idling, the loss is filled up. kinda hybrid, my prius do this every day.
in fakt i did this with the santamos AC and the little caravan behind, uphill the AC was switched off and the car maintained the speed.
kurzer Gruß
Prius II
Hyundai Santamo
