Old 07-15-2008, 01:50 PM   #51 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello,
Okay, from Daox's CdA list:
Make Model Year Cd Height (In) Width (In) Frontal Area (ft^2) CdA
Scion Xa 2004 - 2007 0.31 60.2 66.7 23.4 7.26
So, my number is a little low -- or the official number is a little high?
Old 07-15-2008, 02:02 PM   #52 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
That number is a calculation based on an average. Its unfortunately not an official number. If you can find one I'd gladly use it. The average is based on Hucho's findings that you can take length X width and multiply by .81 and come up with a good approximation. Actual measurement is likely much more accurate. I'll actually be updating that list real soon with some additional Saturn info.
I had also changed my formula back (I was using a different one) that was comming up with a greater frontal area. The new calculation shows your xA as 22.6 ft^2.
Old 07-15-2008, 02:57 PM   #53 (permalink)
Josepha - '08 xD
Hi,
I'll try taking another photo with a longer lens; and I'll ask someone to run this photo through some corrective software, which can correct the perspective based on the specific lens and camera. (I'm using a Nikon D40x with the standard kit lens.) DataCAD is quite accurate -- it'll all come down to the polyline that I trace...
Old 07-17-2008, 10:20 PM   #54 (permalink)
Josepha - '08 xD
Hiya,
An update on the first tankful with the Plexiglas rear wheel skirts -- they added ~1-1 1/2mpg, which is certainly something, but a bit less than I'd hoped. I got my best mileage so far -- 47.5mpg, which is ~0.8mpg better than my previous best tankful.
I will be getting a sheet of Coroplast on Monday (or so), so I will make a new version that cover up more of the wheel -- they will have to wedge out at the bottom to clear around the wheel. Maybe this will improve things some more?
After that, I'm going to try some metal foil tape on the alloy wheels (though this will not be able to cover more than half, due to the pattern and the location of the valve stem). And, I'm hoping to do something with the front wheels; just not full covers. And I'd like to finalize the upper grill block, and possibly do a partial lower grill block, too.
Old 07-24-2008, 02:40 PM   #55 (permalink)
Josepha - '08 xD
Hi y'all,
Updating this thread: I've added AirTabs (pictures and results to come), and I've switched to Gorilla Tape for the grill block. The WeatherSeal tape is pretty strong, but it shirinks a lot, and needs full contact to stick well. It has been lifting off around the fog lights and the grill had been barely staying put; and it finally let go in the heavy rain we've been getting lately.
I got a sheet of dark blue Coroplast today! So, this weekend will be devoted to making some new wheel skirts out of it, that cover more of the wheel. I'm going to have to find some 5/32" metal rod to stiffen the lower edge; or should it be stiff enough on it's own?
Old 07-24-2008, 02:50 PM   #56 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
Nearly every skirt I've seen has a support bar at the bottom and at higher speeds or hot temps, that plastic is going to bend, warp and wobble. Guess it depends on how close they are to the tires/wheels.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-24-2008, 05:30 PM   #57 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
5/32" music wire
I think I've seen the 5/32" rod at Ace hardware in the dowel area.
Many hobby shops (RC Airplane etc) carry it too. Call ahead and save gas..
Nope, I also agree that coro is not going to be firm enough to hold it's shape
when under windloading.
If you were to use it to make some small air dams for the tires, it might be
stiff enough, if you put the corrugations going vertically.
(It's much harder to bend in that direction).
I've been thinking of making some for my tires, but can't decide on what size they should be.
This one only looks about 3" tall..?.
Cheers,
Rich
Old 07-25-2008, 12:00 AM   #58 (permalink)
Josepha - '08 xD
Hi,
I go every Friday night to my local slot car track to race, and I'll check to see what he has in stock.
Old 07-28-2008, 02:10 PM   #59 (permalink)
Josepha - '08 xD
Hi,
I've rebuilt the wheel skirts out of dark blue Coroplast -- I'm pleased with how they came out. Pictures soon, and data after that.
I'm not optimistic that the Airtabs are helping -- in fact, it seems like they are hurting my MPG. I don't know (yet) for sure, because it rained buckets (so I had to use A/C) and I've had four people in the car for much of my recent driving. But, after my commute to work this morning, I was only able to raise the average from 39.7 to 41.1mpg. Considering that I have averaged 45+ for the past 11 tankfuls, and my worst tank recently was 42+ -- I'm not holding my breath.
Old 08-14-2008, 02:06 PM   #60 (permalink)
Josepha - '08 xD
Hi,
I've removed the AirTabs because they were hurting the MPG (by ~3mpg).
I also just removed the Gorilla tape from the "chin" -- I had used it to seal up the air vents, because I thought that if all the air went through the radiator, it would help. In fact, sealing it up hurt my MPG.
I have also done a partial block (covering about 2/3's) of the lower grill opening, and while I don't know if it is helping improve the MPG's yet -- but it is not hurting the temps! Not even a little bit...how much extra grill is there?
grille block
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/scion-xa-aero-mods-2969.html
Posted By For Type Date
Volkswagen brings 260-mpg XL1 Concept a step closer to reality - Autoblog Green This thread Refback 07-05-2011 03:29 AM
How bad do you want to get better mileage??? - Page 5 This thread Refback 06-10-2011 05:05 PM
Video Mirrors - "eyes forward" system - Page 2 - ApteraForum.com - Unofficial Aptera Car Forum This thread Refback 06-03-2011 05:52 PM
How much do Rear Spoilers hurt MPG? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback 04-28-2011 02:02 PM
SPCR • View topic - Super Efficient Cars [very large pictures] This thread Refback 04-13-2011 05:50 PM
Volkswagen brings 260-mpg XL1 Concept a step closer to reality — Autoblog Green This thread Refback 01-26-2011 10:49 AM
Zombie Squad • View topic - Feul Efficiency in a BOV This thread Refback 01-23-2011 11:16 PM
Page 2: Quick weight reduction and slipperiness-- worth it? - Motor Trend The General Forum Forum This thread Refback 12-13-2010 06:47 PM
Neil Blanchard Designs: More ways for auto makers to build more efficient vehicles - Updated 29 June 2010! This thread Refback 11-26-2010 09:09 PM
Nissan Leaf snags 99 mpg rating on official EPA sticker — Autoblog Green This thread Refback 11-24-2010 04:20 PM
Will we ever replace the standard rear- and side-view mirror? - Autoblog Green This thread Refback 11-07-2010 09:13 AM
Neil Blanchard Designs: Aerodynamic modifications to save gasoline This thread Refback 10-10-2010 11:43 PM
Neil Blanchard Designs: "eyes forward" Video Mirrors on my xA This thread Refback 09-23-2010 04:09 AM
xA MPG Hypermiling Quest - Scionlife.com This thread Refback 08-20-2010 02:45 AM
SocialNetworkInc.com: Cloud Vision This thread Refback 08-14-2010 08:54 AM
How much do Rear Spoilers hurt MPG? - Corral.net : Ford Mustang Forums This thread Refback 08-02-2010 05:32 PM
Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 07-19-2010 05:58 AM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 05-20-2010 02:56 PM
3 posts tagged ?ecodriving? - NeilBlanchard?s Blog on Vox This thread Refback 04-27-2010 06:20 PM
More ways for auto makers to build more efficient vehicles - Updated 13 Apr 2010! - Vox This thread Refback 04-15-2010 07:32 PM
Ford creates suggestion box for consumers, what do you want? — Autoblog Green This thread Refback 04-14-2010 01:19 PM
3 posts tagged ?video mirrors? - NeilBlanchard?s Blog on Vox This thread Refback 04-12-2010 03:03 AM
6 posts from 2008 - NeilBlanchard?s Blog on Vox This thread Refback 04-08-2010 03:49 PM
EcoDriving & Other Vehicle Efficiency Improvements (Page 2) - Future Car Reports This thread Refback 03-28-2010 06:25 PM
silentpcreview.com | View topic - Super Efficient Cars [very large pictures] This thread Refback 03-26-2010 10:24 AM
Improving Vehicle Efficiencies -- A List! - Electric A!D This thread Refback 01-27-2010 05:23 PM
"eyes forward" Video Mirrors on my xA - Vox This thread Refback 01-25-2010 08:56 AM
How much do Rear Spoilers hurt MPG? - Corral Forums This thread Refback 01-07-2010 11:34 PM
5 posts tagged ?aerodynamic drag? - NeilBlanchard?s Blog on Vox This thread Refback 12-26-2009 12:13 PM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 12-24-2009 02:13 AM
12 posts from 2009 - NeilBlanchard?s Blog on Vox This thread Refback 11-30-2009 03:23 PM
Production Aptera 2e leaked again on forum — Autoblog Green This thread Refback 10-30-2009 01:09 AM
What if... the Aptera 2e had a EESU? - Page 6 - ApteraForum.com - Aptera Car Forum This thread Refback 10-09-2009 11:17 AM
Greenlings: Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 10-01-2009 11:58 PM
Ask AutoblogGreen: Do electric vehicles need front air intakes? — Autoblog Green This thread Refback 08-29-2009 10:37 AM
Posts (page 2) - NeilBlanchard’s Blog on Vox This thread Refback 08-23-2009 12:16 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 09:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
