Old 09-11-2008, 07:36 PM   #81 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
I do like having a digital camera! (Nikon D40X) Here are some pictures of the current collection of aero mods on my xA:
I've significantly closed down the front air intakes, and yes the coolant temps are completely fine -- come winter, I will have to close them even more; if not completely.
I've added the foil tape to the front rims -- this probably only helps marginally. I need to make some Coroplast fender extensions to the front and top of the front wheel openings.
I've removed the front mudflaps. This should have been done ages ago! I think it has helped me gain ~0.5-0.8mpg, at least. The average climbed that much in ~100 miles, on a 300 mile average.
The rear wheel skirts are now shorter (like the acrylic ones I made first -- I found that when they stick out into the air stream, they don't help as much. The lesson seems to be cover as much as possible without protruding into the air flow -- it is better to cover less, and stay as flush as possible. These still stick out a little bit (using the 1/8" steel rod inside the bottom corrugation tube), so they clear the tire and the wheel -- but this is a very gentle sloping wedge.
The rear underpan has a bit more tape on it to be sure to hold it firmly in place, and to minimize air getting in above it...
Old 09-12-2008, 01:56 AM   #82 (permalink)
Boxy is Sexy
Z man's Avatar
xBox - '05 xB
90 day: 40.85 mpg (US)
Send a message via AIM to Z man
That's awesome. Now to make that nice xA (I like them) look normal!
I have a 3x4 ft. piece of Coroplast for an undertray,
is Gorilla Tape a good adhesive? I have zip ties to use as well.
Old 09-12-2008, 07:01 AM   #83 (permalink)
Josepha - '08 xD
Hello,
Yes, Gorilla tape is quite sticky and strong. It does react to temperature change; the grill block is shrinking a bit, though the Gorilla tape is still better there than the 3M transparent duct tape (which is better in some situations than the Gorilla), and a lot better than the Weather Strip clear tape.
Old 09-14-2008, 09:40 PM   #84 (permalink)
Josepha - '08 xD
Hi,
I'm currently starting a homemade version of ZigZag Tape (or is it ZZ Tape) made from Gorilla tape and some pinking shears.
Old 09-14-2008, 11:00 PM   #85 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
Looking slick Neil
Nice pics! I have to admire your new skirt installation.
Are you going to do anything to the rear rims?
and, Where are you going to use the ZZ tape?
Cheers,
Rich
Old 09-14-2008, 11:09 PM   #86 (permalink)
Josepha - '08 xD
Hi & thanks!
I've put some around the mirrors, and down the C-pillars (to be extended down further), so far. I should also do the A pillars I think. It's back to commuting tomorrow, so I see if they make any noticeable differences.
The cooler weather (and rain, requiring some defrost/AC action!) has caused my FE to drop a bit -- the tank I put in today yielded 44.31, which dropped my 90 day average from 46 to 45.9mpg...
Old 09-15-2008, 12:01 AM   #87 (permalink)
Silver Turtle - '02 Focus Zx3
90 day: 38.83 mpg (US)
^^ Put some behind the tires (flow detatches behind the wheel well)...
And tell me how it works out because I need tape to do the same thing but I do not know which tape (I am thinking color tape that way I can match it to my cars exterior (silver)... but something that also sticks forever that way I can have it there at least a year before I have to re-do it).
Old 09-19-2008, 09:24 AM   #88 (permalink)
Josepha - '08 xD
Hiya,
So far, here's where I've put my homemade zigzag tape:
I'm planning on adding (at least) a second row a coupla' inches behind the first one on the 'C' pillar. So far so good, with these -- my mileage has gone back up, after decreasing as the weather cools. Traffic has gotten worse (it's after Labor Day, after all), but I have figured out how to get 40-50mpg at ~10-15mph: just put it in 3rd or fourth gear and let the engine idle (or just use a tiny bit of throttle)!
Old 09-19-2008, 09:45 AM   #89 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
that's exactly what i've been meaning to do for some time now.
would be nice to tuft test these turbulators... how much difference in FE did you see from these?
the ones on the lip spoiler remind me of my sawtooth trailing edge theory
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 09-19-2008, 11:40 AM   #90 (permalink)
"but I have figured out how to get 40-50mpg at ~10-15mph: just put it in 3rd or fourth gear and let the engine idle (or just use a tiny bit of throttle)!"
I've been using engine-idle mode for years, just about every time I would get stuck in very slow moving traffic.. But, I was dumb and never used anything but 1st or 2nd gear! However, I did need to move very slowly.. 10 or 15 would have been too fast.
The tricky part for me is letting the clutch out so slowly that the ICE doesn't notice.
Cheers,
Rich
grille block
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/scion-xa-aero-mods-2969.html
Posted By For Type Date
Volkswagen brings 260-mpg XL1 Concept a step closer to reality - Autoblog Green This thread Refback 07-05-2011 03:29 AM
How bad do you want to get better mileage??? - Page 5 This thread Refback 06-10-2011 05:05 PM
Video Mirrors - "eyes forward" system - Page 2 - ApteraForum.com - Unofficial Aptera Car Forum This thread Refback 06-03-2011 05:52 PM
How much do Rear Spoilers hurt MPG? - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback 04-28-2011 02:02 PM
SPCR • View topic - Super Efficient Cars [very large pictures] This thread Refback 04-13-2011 05:50 PM
Volkswagen brings 260-mpg XL1 Concept a step closer to reality — Autoblog Green This thread Refback 01-26-2011 10:49 AM
Zombie Squad • View topic - Feul Efficiency in a BOV This thread Refback 01-23-2011 11:16 PM
Page 2: Quick weight reduction and slipperiness-- worth it? - Motor Trend The General Forum Forum This thread Refback 12-13-2010 06:47 PM
Neil Blanchard Designs: More ways for auto makers to build more efficient vehicles - Updated 29 June 2010! This thread Refback 11-26-2010 09:09 PM
Nissan Leaf snags 99 mpg rating on official EPA sticker — Autoblog Green This thread Refback 11-24-2010 04:20 PM
Will we ever replace the standard rear- and side-view mirror? - Autoblog Green This thread Refback 11-07-2010 09:13 AM
Neil Blanchard Designs: Aerodynamic modifications to save gasoline This thread Refback 10-10-2010 11:43 PM
Neil Blanchard Designs: "eyes forward" Video Mirrors on my xA This thread Refback 09-23-2010 04:09 AM
xA MPG Hypermiling Quest - Scionlife.com This thread Refback 08-20-2010 02:45 AM
SocialNetworkInc.com: Cloud Vision This thread Refback 08-14-2010 08:54 AM
How much do Rear Spoilers hurt MPG? - Corral.net : Ford Mustang Forums This thread Refback 08-02-2010 05:32 PM
Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 07-19-2010 05:58 AM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 05-20-2010 02:56 PM
3 posts tagged ?ecodriving? - NeilBlanchard?s Blog on Vox This thread Refback 04-27-2010 06:20 PM
More ways for auto makers to build more efficient vehicles - Updated 13 Apr 2010! - Vox This thread Refback 04-15-2010 07:32 PM
Ford creates suggestion box for consumers, what do you want? — Autoblog Green This thread Refback 04-14-2010 01:19 PM
3 posts tagged ?video mirrors? - NeilBlanchard?s Blog on Vox This thread Refback 04-12-2010 03:03 AM
6 posts from 2008 - NeilBlanchard?s Blog on Vox This thread Refback 04-08-2010 03:49 PM
EcoDriving & Other Vehicle Efficiency Improvements (Page 2) - Future Car Reports This thread Refback 03-28-2010 06:25 PM
silentpcreview.com | View topic - Super Efficient Cars [very large pictures] This thread Refback 03-26-2010 10:24 AM
Improving Vehicle Efficiencies -- A List! - Electric A!D This thread Refback 01-27-2010 05:23 PM
"eyes forward" Video Mirrors on my xA - Vox This thread Refback 01-25-2010 08:56 AM
How much do Rear Spoilers hurt MPG? - Corral Forums This thread Refback 01-07-2010 11:34 PM
5 posts tagged ?aerodynamic drag? - NeilBlanchard?s Blog on Vox This thread Refback 12-26-2009 12:13 PM
EcoModder.com: Vehicle Efficiency Improvements | Facebook This thread Refback 12-24-2009 02:13 AM
12 posts from 2009 - NeilBlanchard?s Blog on Vox This thread Refback 11-30-2009 03:23 PM
Production Aptera 2e leaked again on forum — Autoblog Green This thread Refback 10-30-2009 01:09 AM
What if... the Aptera 2e had a EESU? - Page 6 - ApteraForum.com - Aptera Car Forum This thread Refback 10-09-2009 11:17 AM
Greenlings: Will we ever replace the standard rear- and side-view mirror? — Autoblog Green This thread Refback 10-01-2009 11:58 PM
Ask AutoblogGreen: Do electric vehicles need front air intakes? — Autoblog Green This thread Refback 08-29-2009 10:37 AM
Posts (page 2) - NeilBlanchard’s Blog on Vox This thread Refback 08-23-2009 12:16 PM
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Scion XA in PA goodblues Introductions 25 08-27-2010 09:49 AM
Aero mods on 06 civic c0da Aerodynamics 28 05-20-2009 04:17 PM
Planning Aero Mods Doofus McFancypants Aerodynamics 30 06-15-2008 07:03 PM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
