Old 06-17-2010, 11:30 AM   #1 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Second-gen Stop-Start technology coming 2013
I think Stop-Start tech should be required on all ICE powered cars within a year or two.
Valeo's second-gen stop-start technology coming to 1M diesel Peugeots, Citroëns by 2013 — Autoblog Green
Frank Lee (06-17-2010), Piwoslaw (06-17-2010)
Old 06-17-2010, 11:34 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Too bad the EPA testing doesn't show any time stopped idling. This really is the reason we don't have start/stop here yet. I think Darin posted something a while ago about this and Nissan commenting on the EPA testing.
Old 06-17-2010, 02:36 PM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
I can't wait for someone to hack it for ecomodder use: manually adjustable kick-in speed. Tailor it your own P&G needs.
Best of all, this stop-start system could be easily adapted to almost any powertrain combo out there as a quick, relatively cheap way to increase fuel efficiency.
Could that mean retrofittable?
I'd like to read that. Do you remember the link? I couldn't find it.
Piwoslaw's Peugeot 307sw modding thread
Old 06-17-2010, 03:05 PM   #4 (permalink)
Old Retired R&D Dude
Little Red - '012 Prius c 2 Two
90 day: 26.38 mpg (US)
Transporter - '09 Escape XLS
Yeah, I hope someone makes a add-on i-StARS type kit for the Fords..
Could really help out with city driving.. (Which is about 90% of my driving these days).
Buying that i-StARS equipped car is sure to invoke Murphy's Law to insure
that you never hit another long red light again..
Cheers,
Rich
Old 06-17-2010, 03:08 PM   #5 (permalink)
The Crimson Crawler - '04 Elantra GLS
90 day: 36.71 mpg (US)
And would that be such a bad thing?
Old 06-17-2010, 03:18 PM   #6 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
Here it is:
Mazda: EPA Test Keeps Stop-Start Out | The Truth About Cars
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 06-17-2010, 03:23 PM   #7 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
Here's a little bit more info
Valeo sets hybrid stop-start solutions
Old 06-17-2010, 06:23 PM   #8 (permalink)
Originally Posted by PaleMelanesian View Post
Wow! That's a lot of reading when you follow the links..
Some very interesting comments about the technology and,
the politics of the technology.
One commenter noted that if the EPA tested with real-life stops
embedded in the MPG tests, Honda and Prius type hybrids would rule,
since they use zero fuel while stopped.. (I guess the same is true of the Ford hybrids).
To do it right, you need to dump the small starter and alternator,
for a larger more robust motor-generator system. Hence the price tag.
Not really a cheap retrofit path for the older cars..
I guess maybe I'll keep doing it the old fashion way.. Just drive less..
Cheers,
Rich
Old 06-17-2010, 11:34 PM   #9 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Three cables leaving the alternator and running to a gizmo with a giant heatsink... it's a three-phase AC motor with its own inverter. Same setup I've got in my car, but on a different scale. Also, I presume their inverter is 12V, thus saving the expense of a second battery.
As far as a DIY retrofit, I'm sure you could fit it to any car that has a big enough 12V battery. I assume this system does "regenerative alternatoring": charging your battery at a few hundred amps while you brake.
Just wait for someone to crash a car that has this system, then tell the U-pull that you're there to buy an alternator for your Peugeot. $15 later, you have MHYGALE (Mild HYbrid GenerALisablE).
Old 06-18-2010, 06:27 AM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
Oh man, you're onto my scheme!
Certain subjects are immune to logic? Frank Lee The Lounge 185 02-03-2011 09:02 AM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
SF to allow stop and roll for cyclists SVOboy Alternative Transportation 18 07-29-2008 03:39 PM
