Old 06-06-2008, 03:36 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Signal Generator
Not sure where this goes, but it is basically two duinos. One (the plain chip and crystal) has been programmed in arduino to simulate a vehicle vss and injector signal, and the other is running the mpguino code. The test code is at the bottom. Now it isn't single digit microsecond accurate, but it also isn't limited by the number of timers either. With this approach you can generate a lot of different signals, i.e. buttons, etc. And since both the guino and the signal generator are connected to the computer simultaneously it is quite possible to have a PC program with all kinds of scenarios that tell the signal generator what to generate and get the result from the gunio to see if it is correct.
PHP Code:
//GPL Software
//cheesey signal generator, made for bench testing the mpguino
//signal generator pins
#define sig1Pin 2   //inj
#define sig2Pin 3
//overflow counter used by millis()
extern volatile unsigned long timer0_overflow_count;
unsigned long lastMicroSeconds=millis() * 1000;
unsigned long microSeconds (void){
unsigned long tmp_timer0_overflow_count
unsigned long tmp
byte tmp_tcnt0
cli(); //disable interrupts
tmp_timer0_overflow_count timer0_overflow_count
tmp_tcnt0 TCNT0
sei(); // enable interrupts
tmp = ((tmp_timer0_overflow_count << 8) + tmp_tcnt0) * 4;
  if((
tmp<=lastMicroSeconds) && (tmp<4293967296))
    return
microSeconds();
lastMicroSeconds=tmp;
  return
tmp;
unsigned long elapsedMicroseconds(unsigned long startMicroSecondsunsigned long msec ){
  if(
msec >= startMicroSeconds)
    return
msec-startMicroSeconds;
  return
4294967295 - (startMicroSeconds-msec);
metro signal generator notes:
//#define vssPulsesPerMile 10000ul
//#define microSecondsPerGallon 267857143ul //injector flow rate
@20mph, 4th gear
~48mpg
~44000uS injector open time per 1/2 second
18 inj pulses per 1/2 second
55 vss pulses per 1/2 second
therefore:
sig1, off for 2444uS, on for 25333uS
sig2, on for 16000uS, off for 2180uS
unsigned long sig1Start//injector
byte sig1State HIGH//injector 1=closed
unsigned long sig2Start//vss
byte sig2State LOW//vss
#define sig1PinOffTime 2444
#define sig1PinOnTime 25333
#define sig2PinOnTime 16000
#define sig2PinOffTime 2180
void setup (void){
pinMode(sig1Pin,OUTPUT);
pinMode(sig2Pin,OUTPUT);
void loop (void){
digitalWrite(sig1Pin,sig1State);
digitalWrite(sig2Pin,sig2State);
sig1Start microSeconds();
sig2Start sig1Start;
  while(
true){
//snapshot of the time variables:
unsigned long tmp microSeconds();
unsigned long tmp1 elapsedMicroseconds(sig1Starttmp);
unsigned long tmp2 elapsedMicroseconds(sig2Starttmp);
//sig 1 timing logic
if(sig1State==HIGH){
      if (
tmp1>=sig1PinOnTime){
sig1Start=tmp;
sig1State=LOW;
    }else{
      if (
tmp1>=sig1PinOffTime){
sig1Start=tmp;
sig1State=HIGH;
//sig 2 timing logic
if(sig2State==HIGH){
      if (
tmp2>=sig2PinOnTime){
sig2Start=tmp;
sig2State=LOW;
    }else{
      if (
tmp2>=sig2PinOffTime){
sig2Start=tmp;
sig2State=HIGH;
//sig3?  sigX?
Old 06-08-2008, 03:45 PM   #2 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Firefly 3dr
90 day: 40.08 mpg (US)
What is the signal logic on the VSS and injector line? I'd like to make an interface for my carputer to do FE calculations.
Old 06-08-2008, 04:15 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
It is basically a 5 volt square wave defined by these lines in the code:
sig1 (simulating the injector signal) is off for 2444 microseconds and on for 25333 microseconds, roughly.
sig2 (simulating the vss signal) is on for 16000 microseconds and off for 2180 microseconds, roughly.
So you going to start from scratch, or can you help us troubleshoot the guino? It would be downright trivial to send the instant raw data out the serial port on the guino and collect it on the carpc and make sense out of it there. I do it all the time for debugging.
Old 06-08-2008, 04:50 PM   #4 (permalink)
awillard69's Avatar
Dakota - '00 Dakota Club Cab, Sport
90 day: 18.57 mpg (US)
Jeep - '01 Wrangler TJ Sport
90 day: 18.46 mpg (US)
You beat me to the end. My 555 is working, but not very precisely. While its accurate, without a scope, I'm having trouble zeroing in on trustworthy streams.
So, let me get this straight, you have a basic ATMEGA168 chip, that you loaded using your Freeduino board, or the load cable, then placed that code loaded chip to your solderless breadboard with the bare bones components for a functioning chip. You then power it from the same place as the MPGuino and tap its outputs.
I may just have to break down and buy some more Freeduinos to catch up.
My soldering iron is heating up so I can migrate my LCD and input interfacing components to a proto shield. I'm trying to make mine look less like a spaghetti ball on the bench.
Old 06-09-2008, 04:12 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
That's pretty much it. I bought some 20mhz PDIP atmega 168's and some 16mhz crystals after I cooked one atmega, then wrestled a bootloader on them by putting them in my freeduino board socket and mucking around with the parallel port ICSP programmer (not for the faint of heart), then I could program it via the USB/Serial port on the board and use plain old arduino IDE and code.
NCK had some chips with bootloaders on them, but no crystals, and when I looked they did not have chips in stock, so as hokey and painful as the parallel programmer can be to get working, it has proved to be invaluable. It's brought back a couple chips after experiments that have gone wrong and cost me nothing
Course the real nice thing about this arrangement is that I can create cheap little devices, but anybody with a duino can also use what has been written very easily.
Edit: I was just checking out the iduino and noticed that fundamental logic, http://www.spiffie.org has atmegas with bootloaders preloaded and crystals, as well as a breadboard usb duino kit for $18! I had to get one at that price (plus a couple more atmegas and crystals)
Old 06-09-2008, 08:27 PM   #6 (permalink)
Cxy Hatch - '92 Civic CX
0ftlbs - '05 S2000
Great work DCB. Thanks for all your help on this project as far as debugging the software (and writing it hahaha).
I may build one of these with my spare board. I always buy spares when it comes to components....I've got a habit....
Old 06-10-2008, 12:10 PM   #7 (permalink)
awillard69's Avatar
I got my cluster of wires pushed to the proto shield from NKC. But, then ran into several issues.
The first was the size of the holes are tight for the Zener diodes, or if you have larger watt resistors. Not a big deal, but does require some persuasion and the small area makes it challenging.
The second problem is more of an issue. Basically, the trace across the center of the board for 5V is not connected, just solder pads; the ground is OK.
I contacted NKC and they acknowledged my find. They were prompt, but I would wait for a new generation board before getting another proto shield from them.
All in all, it went great, aside from the issues with "placement on the fly". And, it looks good, piggy backed on the Guino. Still not as compact as a custom PCB setup, but very friendly for plug-and-go with any Freeduino board, snap in, snap out.
I'm waiting for my other Freeduino's to arrive so I can assemble the generator and get back to testing this thing.
Old 06-15-2008, 01:35 PM   #8 (permalink)
awillard69's Avatar
Have you changed or updated your generator code? I've got it running on a 2nd Freeduino, straight inputs, not resistors.
It looks like I'm showing 55-58 mpg. Is that what you are getting?
I show MH 40.0x and MG ~57.
Not related directly to the generator, when I display the CPU % screen, it seems to revert back to the startup, like a reset as the MI reverts back to near 0.
I get it if I cycle left once, or right 6 times.
I'm not quite sure if it's the code somehow resetting the CPU or something else. Version 0.61.
The generator makes it nice to see it actually running.
Old 06-15-2008, 09:28 PM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
I've not touched the signal generator code since fixing the 72 minute issue. I do keep messing with the microseconds per gallon and vssTicsPermile though but 57/58 mpg @40mph sound just right for the last version.
re:reset, currently , hitting left button and middle button simultaneously will reset the tank trip, hitting right and middle will reset the current trip. Is it possible that the middle button is getting "fat fingered" when hitting the left or the right button?
Old 06-16-2008, 10:16 AM   #10 (permalink)
awillard69's Avatar
I've checked and the buttons don't appear to be solder bridged or anything. And the buttons are far enough apart to not likely be fat fingered. But, it also happens if I right button to that screen, also.
But it appears to be resetting the program, ie running setup() again.
With my current configuration, if I press the reset button on the Freeduino the LCD goes "one line" on me - known issue. This doesn't happen, so I'm not quite sure it's a full on restart, but like it's just running setup() again somehow. I went looking through the Guino code, looking for a possible hosed pointer or something, something where a memory address is getting trounced. Nothing jumped out at me. It could be a memory corruption or allocation/deallocation issue within the arduino program code. A bit far fetched maybe. Does it not happen for you?
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 03:29 PM
VSS, tach, injector signal logic wikityler Instrumentation 2 07-21-2008 12:02 AM
New freeway signs.. traffic signal conspiracy Chris D. EcoModding Central 36 06-02-2008 02:51 PM
Opengauge/MPGuino development: Freeduino signal processing dcb OpenGauge / MPGuino FE computer 6 04-16-2008 10:40 AM
Very clever knee brace generator - 5 watts while walking - no extra effort. MetroMPG The Lounge 6 02-09-2008 01:38 AM
