Old 11-12-2013, 07:57 AM   #1 (permalink)
My C-Max - '13 Ford C-Max SEL
"Snow Flow" testing?
Hey Guys,
I know I am not the first to think of this but, I wanted to ask;
We had our first snow yesterday. I noticed some specific air flow paterns preserved in the snow over my car. One thing I noticed in particular was the radius formed around the 4 air openings in my grille blocks. This happens to be the same radius I plan on replicating with materials I have on order (black Delrin that I will radius with a router). Anyway, the snow formed a fantastic looking radius in that area and some interesting shapes over the body of the car.
Oh, one major thing I noticed too is the relatively even spread over the body of the car versus my wife's car. The airflow is, obviously, FAR smoother omve my car than hers, as evidenced by the snow pattern.
Has anyone else used snow flow patterns as a way to do aero work?
Matt
Old 11-12-2013, 09:45 AM   #2 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Snow patterns are a standard way of visualizing aero (you can also use the road dust patterns left after driving on dirt roads to visualize aero). Here are some older threads on the subject:
http://ecomodder.com/forum/showthrea...-mod-1129.html
http://ecomodder.com/forum/showthrea...ack-20110.html
http://ecomodder.com/forum/showthrea...est-16191.html
http://ecomodder.com/forum/showthrea...ure-11745.html
aerocivic.com
Old 11-12-2013, 03:19 PM   #3 (permalink)
See Post #13-16
http://ecomodder.com/forum/showthrea...a-19525-2.html
More from that thread:
http://ecomodder.com/forum/showthrea...tml#post399204
The Following 3 Users Say Thank You to kach22i For This Useful Post:
aerohead (11-13-2013), BamZipPow (02-05-2015), Cd (02-03-2015)
Old 02-02-2015, 11:44 PM   #4 (permalink)
UPDATE: 02/02/2015
A near snow-less winter this year after record snow fall last year.
Here in Michigan we got 14.1 inches of snow on Super Bowl Sunday.
Note: no cab on my truck, that's snow!
Old 02-02-2015, 11:58 PM   #5 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Is it an optical illusion or does the snow "kammback" actually curve, rather than being straight/flat?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 02-03-2015, 05:53 PM   #6 (permalink)
curve
It looks sway-backed to me,like some sweet,worn-out,old mares we used to rent for a day's horseback riding in my childhood.
Old 02-04-2015, 05:43 PM   #7 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
Here is my example from last winter:
The Following User Says Thank You to whatmaycome14 For This Useful Post:
Old 02-04-2015, 08:24 PM   #8 (permalink)
Yea, I thought that was odd too.
It did not quite start out that way though.
Taken while snow was at about 12", max peak 32 mph winds coming head on to the truck.
Compare to final snow drifts.
Sort of some crisp edges on the upper parts.
The indented drift or scallop between the wheel-base is interesting.
The front air dam has a pronounced affect.
It is like a well or hole.
Saves on digging it out.
I am not sure what the snow "deposits" actually depict.
I want to assume that they show an idea aerodynamic shape formed by nature, but do not know for sure.
EDIT: I should note that I had no problems with the 14 inches of snow despite the dam only 7-1/2" off the ground.
BamZipPow (02-05-2015), jeff88 (02-05-2015)
Old 02-05-2015, 02:12 PM   #9 (permalink)
Lots of Questions
Looks like the front of your truck is all set! Other than the shelf the bumper makes, your snow test looks just about perfect up there!
That scallop in the foot step is interesting, I would have expected there to be more snow filling the whole indentation, not a scalloped effect.
I wonder why the bed ended up having the curved, rather than straight section?
Best EM Quotes:
