Old 08-02-2017, 06:43 AM   #11 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I would calculate the mph including the charge times. Obviously for a fixed distance like 1000miles you would need to do a bit of optimization...
I would plot the following formula
(Range_at_given_speed)/(time_time_to_cover_distance + charge_time)
This will give you your actual mph over the long run.
The Following User Says Thank You to teoman For This Useful Post:
redpoint5 (08-02-2017)
Old 08-04-2017, 12:53 AM   #12 (permalink)
Speeds above 80km/h are usually worse when it comes to fuel-efficiency.
