04-02-2015, 05:58 PM
#11 (permalink)
State oftheArt InFlowTech
State of the Art Novel InFlow Tech Development; 1-Gearturbine 2-Imploturbocompresssor
State of the Art - Novel InFlow Tech - Featured Project Development;
1-Gearturbine, 2-Imploturbocompressor, Imagen Gallery at Behance
1-GEARTURBINE PROJECT
Rotary-Turbo-InFlow Tech
Atypical InFlow Thermodynamic
Technology Proposal Submission
Novel Fueled Motor Engine Type
Gearturbine Imagen gallery at Behance
*State of the art Innovative concept Top system Higher efficient percent.*Power by bar, for Air-Planes, Sea-Boats, Land-Transport & Dynamic Power-Plant Generation.
-Have similar system of the Aeolipile Heron Steam device from Alexandria 10-70 AD. -New Form-Function Motor-Engine Device. Next Step, Epic Design Change, Broken-Seal Revelation. -Desirable Power-Plant Innovation.
YouTube; * Atypical New • GEARTURBINE / Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Thrust Way Type - Non Waste Looses
-This innovative concept consists of hull and core where are held all 8 Steps of the work-flow which make the concept functional. The core has several gears and turbines which are responsible for these 8 steps (5 of them are dedicated to the turbo stages). The first step is fuel compression, followed by 2 cold turbo levels. The fourth step is where the fuel starts burning – combustion stage, which creates thrust for the next, 5th step – thrust step, which provides power to the planetary gears and turbines and moves the system. This step is followed by two hot turbo steps and the circle is enclosed by the final 8th step – bigger turbine. All this motion in a retrodynamic circumstance effect, wich is plus higher RPM speed by self motion. The Reaction at front of the action.
*8-X/Y Thermodynamic CYCLE - Way Steps:
1)1-Compression / bigger
2)2-Turbo 1 cold
3)2-Turbo 2 cold
4)2-Combustion - circular motion flames / opposites
5)2-Thrust - single turbo & planetary gears / ying yang
6)2-Turbo 2 hot
7)2-Turbo 1 hot
8)1-Turbine / bigger
-With Retrodynamic Dextrogiro vs Levogiro Phenomenon Effect. / Rotor-RPM VS InFlow / front to front; "Collision-Interaction Type" - inflow vs blades-gear-move. Technical unique dynamic innovative motion mode. [Retrodynamic Reaction = When the inflow have more velocity the rotor have more RPM Acceleration, with high (XY Position) Momentum] Which the internal flow (and rotor) duplicate its speed, when activated being in a rotor (and inflow) with [inverse] opposite Turns. The Reaction at front of the action. A very strong Novel torque power concept.-Non waste parasitic looses for; friction, cooling, lubrication & combustion.
-Shape-Mass + Rotary-Motion = Inertia-Dynamic / Form-Function Wide [Flat] Cylindrical shape + positive dynamic rotary mass = continue Inertia positive tendency motion. Kinetic Rotating Mass. Tendency of matter to continue to move. Like a Free-Wheel.
-Combustion 2Two continue circular [Rockets] flames. [ying yang] opposite one to the other. – With 2TWO very long distance INFLOW [inside propulsion] CONDUITS. -4 TURBOS Rotary Total Thrust-Power Regeneration Power System. -Mechanical direct 2two [Small] Planetary Gears at polar position. -Like the Ying Yang Symbol/Concept.
-The Mechanical Gear Power Thrust Point Wide out the Rotor circumference were have much more lever [HIGH Torque] POWER THRUST. -No blade erosion by sand & very low heat target signature profile. -3 points of power thrust; 1-flow way, 2-gear, 3-turbine. *Patent; Dic. 1991 IMPI Mexico #197187 All Rights Reserved. Carlos Barrera.
·2-IMPLOTURBOCOMPRESSOR; One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion Concept.
Imploturbocompressor Imagen Gallery at behance
*·“Excellence in Design" because is only one moving part. Only one unique compression step. Inflow and out flow at the same one system, This invention by its nature a logic and simple conception in the dynamics flow mechanics area. The invention is a wing made of one piece in a rotating motion, contained in a pair cavity system connected by implocavity, and interacting dynamically with a flow, that passes internally "Imploded" through its simple mechanism. This flow can be gas (air) or liquid (water). And have two different applications, in two different form-function; this one can be received (using the dynamic flow passage, as a receiver). Or it can be generated (with a power plant, generating a propulsion).
An example cut be, as a Bike needs a chain to work from motor to wheel. And for the Imploturbocompressor application, cut be as; in a circumstance at the engine, as an A-activate flow, and with a a tube flow conduit going to the wheel as a B-receiving-flow the work use.
To see a Imploturbocompressor animation, is posible on a simple way, just to check the Hurricane Satellite view, and is the same implo inflow way nature.
And when the flow that is received and that is intended to be used at best, must no necessarily by a exhausting or rejection gas, but must be a dynamic passing gas or liquid flow with the only intention to count it or to measure it. This could be possible at the passing and interacting period when it passes inside its simple mechanism. This can be in any point of the work flow trajectory.
In case the flow that is received is a water falling by gravity, and a dynamo is placed on the rotary bar, the Imploturbocompressor can profit an be obtained by generating? electricity such as obtained by the pelton well, like I say before. The "Imploturbocompressor", is a good option to pump water, or a gas flow, and all kinds of pipes lines dynamic moves.
Or only receive the air-liquid flow, in order to measure its passage with a counter placed on the bar, because when this flow passes through the simple mechanism of a rotating wing made of only one piece it interacts within the implocavities system. And this flow can be air wind, with the difference of can have an horizontal work position, and that particle technical circumstances make an easy way for urban building work new use application, and have wind flow from all the sides 180 grades view. The aforementioned information about this invention refers to technical applications, such as a dynamic flow receiver. (whether being gas or liquid).
With the appropriate power plant and the appropriate dimensioning and number of RPM this invention is also feasible to generate an atmospheric air propulsion and the auto-propulsion of an aircraft. Being an effective and very simple system that implodes and compresses the atmospheric air permits the creation of a new concept of propulsion for aircrafts, due to its simple mechanism and innovative nature. At the place of the aircraft were the system appears and the manner how the propulsion direction can be oriented with a vectorial flow (no lobster tail) with I call "yo-yo system" (middle cut (at the shell) to move, one side loose), guided and balanced is feasible to create a new concept of TOVL-vertical take-off landing, Because the exhaust propulsion can going out radial in all the 360 vectorial positions, going out direct all the time in all the vectors direction. With his rotor cover for an better furtive fly, like going down of a bridge for example.
Likewise, with the due form and dimensioning, and considering the liquid density and the due revolutions for this element there could be generated a propulsion (water) in order to move an aquatic ship, whether on surface or under water. Also can be a good option to pump liquid combustion for a rocket propulsion.
Making a metaphoric comparison with the intention to expose it more clearly for a better comprehension of this innovative technical detail, it would be similar to the trajectory and motion of a dynamic flow compared with a rope (extended) that passes through the system would have now a knot (without obstructing the flow), so the complete way of the flow at the imploturbocompresor system have three direct ways and between make two different turns; direct way (entrance) - turn - direct way (implocavity) - turn - direct way (exit), all this in a 1 simple circular move system concept.
Its prudent to mention that the curves and the inclinations of the blades of a rotating wing made of this invention, is conferred by its shape and function a structural rigidity allowing it to conduct and alter appropriately the dynamic flow passing through its system.
Featured Project Development - State of the Art Novel InFlow Tech: ·1-Gearturbine: Reaction Turbine, ·Rotary-Turbo, Similar System of the Aeolipile ·Heron Steam Device from 10-70 AD, ·With Retrodynamic = DextroGiro/RPM VS LevoGiro/InFlow, + ·Ying Yang Power Type.·2-Imploturbocompressor: Impulse Turbine, ·Implo-Ducted, One Moving Part System Excellence Design, · InFlow Goes from Macro-Flow to Micro-Flow by Implosion/And Inverse, ·One Compression Step.
Reason: fix all the information
12-29-2017, 11:26 PM
#12 (permalink)
State ofthe Art Novel InFlow/1Gearturbine-RotaryTurbo/2Imploturbocompressor-1CompStep
State of the Art - Novel InFlow Tech - Featured Project Development:
1-Gearturbine, RotaryTurbo, 2Imploturbocompressor, One Compression Step:
*Wordpress Blog State of the Art Novel InFlow Gearturbine Imploturbocompressor
*1-GEARTURBINE PROJECT,
Rotary-Turbo-InFlow Tech,
Atypical InFlow Thermodynamic,
Technology Proposal Submission,
Novel Fueled Motor Engine Type:
*1-GEARTURBINE BEHANCE Images Gallery Portafolio
·State of the art Innovative concept Top system Higher efficient percent.*Power by bar, for Air-Planes, Sea-Boats, Land-Transport & Dynamic Power-Plant Generation. -Have similar system of the Aeolipile Heron Steam device from Alexandria 10-70 AD. -New Form-Function Motor-Engine Device. Next Step, Epic Design Change, Broken-Seal Revelation. -Desirable Power-Plant Innovation. Next trend wave toward global technological coming change.
The present invention relates to a compression and pushing motor characterized in that it is composed of a housing, said housing accommodates a rotor rotating in its internal space supported by a pair of gears whose passage coincides with the inner surface of the rotor; A rotor (or core) that internally has flow ducts presented one in reverse of another, balanced these, begin at the point where they end; Has several cavity points for reaction turbines, as well as two combustion chambers isolated by means of a system of nozzles and presented in the manner of poles, that is on opposite sides of one another, but their flow with the same circular direction of the rotor when It rotates; The rotor also has several fluid conduits radially presented; A hollow power transmission rod arranged and traversing in the center of the rotor, which in its interior flows the lubricant and fuel with movement of the ends towards the center, at this point by means of the centrifugal force of the rotor reaches the required parts; In the bar is arranged an air intake fan which by rotating the rotor suction air and introduces it to the internal ducts of the rotor with an initial compression, next to this fan is a current collector that generates the necessary electricity and Together with a coil, activates the current necessary for combustion; A center of the nucleus in which the formation of the internal ducts of the rotor begins and ends (in and out); Said center of the core has arranged a pair of semi-cylindrical cavities housing two pairs of turbochargers said core of the core is diagonally traversed by fluid conduits exiting from the bar to the combustion bed and lubrication points and by the centrifugal force of the rotation Of the rotor sends the fluids to the required points due to their radial direction; Exhaust blades are the point of exit of the exhaust gases that leave the internal ducts of the rotor and contrareaccionan with the fixed blade in the last point of use of propulsion of the motor; Two combustion chambers contained in the rotor's strong ducts when the parts forming it are joined, said chambers have their flame in front of the thrust blade, which is connected by a common shaft to a gear located on the outside of the rotor and Coincides with the internal gear of the housing; A starter motor which by means of a gear engages the starter gear attached to the bar.
·:8-X/Y Thermodynamic CYCLE - Way Steps
2)2-Turbo 1 cold
3)2-Turbo 2 cold
6)2-Turbo 2 hot
7)2-Turbo 1 hot
·2-IMPLOTURBOCOMPRESSOR; Implo-Ducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion Concept.
*2-IMPLOTURBOCOMPRESSOR BEHANCE Images Gallery Portafolio
And when the flow that is received and that is intended to be used at best, must no necessarily by a exhausting or rejection gas, but must be a dynamic passing gas or liquid flow with the only intention to count it or to measure it. This could be possible at the passing and interacting period when it passes inside its simple mechanism. This can be in any point of the work flow trajectory. In case the flow that is received is a water falling by gravity, the Imploturbocompressor can profit an be obtained by generating? electricity such as obtained by the pelton well, like I say before. The "Imploturbocompressor", is a good option to pump water, or a gas flow, and all kinds of pipes lines dynamic moves.
With the appropriate power plant and the appropriate dimensioning and number of RPM this invention is also feasible to generate an atmospheric air propulsion and the auto-propulsion of an aircraft. Being an effective and very simple system that implodes and compresses the atmospheric air permits the creation of a new concept of propulsion for aircrafts, due to its simple mechanism and innovative nature. At the place of the aircraft were the system appears and the manner how the propulsion direction can be oriented with a vectorial flow (no lobster tail) with I call "yo-yo system" (middle cut (at the shell) to move, one side loose), guided and balanced is feasible to create a new concept of TOVL-vertical take-off landing, Because the exhaust propulsion can going out radial in all the 360 vectorial positions, going out direct all the time in all the vectors direction. With his rotor cover for an better furtive fly, like going down of a bridge for example. Likewise, with the due form and dimensioning, and considering the liquid density and the due revolutions for this element there could be generated a propulsion (water) in order to move an aquatic ship, whether on surface or under water. Also can be a good option to pump liquid combustion for a rocket propulsion.
12-30-2017, 03:06 AM
#13 (permalink)
so, basically no change since 03-30-2015, 06:44 PM
12-30-2017, 08:02 AM
#14 (permalink)
Eco-ventor
Judging by the video there hasn't been any progress in 20 years.
When is the working prototype coming?
12-31-2017, 08:06 AM
#15 (permalink)
Master Novice
You know what would be great? It'd be great if you didn't copy/paste what appears to be your entire website when you make a new entry. That would be great.
I don't generally call out language use when the writer is clearly not using his native language, especially when I am not more than marginal in any other language, but this is nearly incomprehensible in many places, and repeating it as many times as you have over the years - without changing a word - doesn't improve matters.
It's not state of the art. The earliest date on this contraption puts it at 1990.
The video cuts away from the part of the letter from Caterpillar in which the engineering department person says "I don't think your design would be applicable for our use." That was a very polite way of saying "we think it's pointless."
I'm struggling to make sense of this thing. It appears to be a supercharger that is also a vacuum pump. Can anyone set me straight if I have missed the mark? I like to think I'm a fairly smart guy but I know there's people way smarter than me on this forum who probably have been able to make more sense of this doohickey.
The Following User Says Thank You to elhigh For This Useful Post:
01-07-2018, 02:48 PM
#16 (permalink)
weirdo
that would be bad English for a cavitation
and cavitation represents the limits of a turbo
the bigger the vacuum cavity the worse off you are
The Following User Says Thank You to ASV For This Useful Post:
02-04-2018, 09:42 PM
#17 (permalink)
+PLUS; *State of the Art, Novel Technology, Featured Project Development / Space, Satellite and Habitat, Power-Plant, Generator, Self-Feed Unit; H2O=>HHO=>H2O=>HHO=>Etc... *4 Systems All in One Unit, One By One, Plus Four-4 Projects added One to Other; *·1-Gearturbine, ·2-Imploturbocompressor, ·3-Dynamic Generator, ·4-Electrolysis System:
·1-GEARTURBINE; Rotary-Turbo-InFlow Tech,Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD * With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses *8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type.
·2-IMPLOTURBOCOMPRESSOR; Implo-Ducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature.
·Note-Plus-This-Two Projects / to complete all the System Work:
(Self-Feed Unit Space Power-Plant-H2O=>HHO)
·3-Dynamic Generator/New Kind.
·4-Electrolysis System/BioDesign.
*(3&4-Hide-Cards-on-the-Hand).
01-07-2019, 10:38 PM
#18 (permalink)
this is an Implocavity similar as an Hurricane
01-07-2019, 10:42 PM
#19 (permalink)
Key projects Images
Key projects Images
01-08-2019, 10:06 AM
#20 (permalink)
Thalmaturge
Originally Posted by JRMichler
If first you don't succeed, always try, try again.
Wall of text Lorem ipsum dolor sit amet, consectetur adipiscing elit. Sed nibh leo, tempus sed ornare quis, accumsan ut neque. Donec ultrices feugiat iaculis. Sed ut arcu vel nisi dignissim porta vel ut diam. Phasellus iaculis nibh ullamcorper tellus egestas, dictum aliquam lectus elementum. Integer efficitur ipsum et massa feugiat ornare. Proin sit amet vestibulum leo, nec porta diam. Nulla at lectus leo. Donec finibus nunc ligula, et semper ex dictum vitae. Nam placerat ipsum lacinia arcu feugiat faucibus. Pellentesque dapibus dui ut suscipit venenatis. Quisque consectetur nulla vitae pulvinar scelerisque. Nullam et pellentesque massa.
Pellentesque accumsan tortor quis diam aliquam, non viverra neque ultricies. Praesent id diam at velit suscipit tempor. Mauris eleifend scelerisque justo, non ullamcorper nunc egestas in. Donec sed nisl non odio sollicitudin convallis. Ut in ex eros. Mauris interdum ante non odio varius posuere. Aenean velit nisl, elementum vitae consequat vitae, tincidunt et nunc. Proin suscipit ipsum eu dui cursus mollis. Sed ex metus, venenatis sed erat vitae, fringilla varius justo. Vestibulum imperdiet maximus lorem, ut tempus odio aliquet non. Duis feugiat, augue non tempus consectetur, lacus turpis convallis lacus, at scelerisque purus erat id eros.
Integer ultrices ac nisl sit amet suscipit. Phasellus lacus dui, aliquam id semper vel, vulputate nec massa. Curabitur bibendum enim felis, sed sodales sem vestibulum at. Vivamus sagittis semper nibh a mollis. Aliquam erat volutpat. Mauris eu vulputate sapien. In pretium mollis diam eget pulvinar. Proin vel mi ac ante eleifend lacinia. Nulla ut accumsan arcu. Curabitur vitae sagittis augue, sed eleifend risus. Etiam vulputate, sem et fringilla pulvinar, lectus metus cursus dolor, a sagittis risus augue sit amet ex. Suspendisse metus massa, feugiat at tincidunt at, scelerisque in sem. Curabitur at posuere lectus. Curabitur condimentum massa quis sem dapibus varius.
Morbi mattis, dui id hendrerit viverra, risus ante commodo velit, sit amet vestibulum neque tellus quis justo. Sed sed sollicitudin nisi. Morbi at sem eros. Duis eu quam dui. Duis varius velit sed enim tincidunt mattis. Phasellus scelerisque rhoncus leo. Curabitur et porttitor lorem, at dictum sem. Vivamus condimentum ac ex sit amet vestibulum. Praesent tortor diam, eleifend nec consectetur at, mollis bibendum magna. Sed elit nisl, aliquet imperdiet auctor volutpat, fermentum a turpis. Proin commodo urna eget ligula feugiat, quis posuere nulla efficitur. Integer varius iaculis ultricies. Aliquam elit neque, lacinia vel arcu at, aliquet ornare erat.
Ut lacus odio, condimentum quis egestas ut, tristique id sem. Aliquam nec consectetur arcu. Duis in risus pharetra, gravida sapien eu, finibus augue. Vivamus nulla neque, suscipit faucibus diam sed, rutrum feugiat turpis. Etiam a sem mattis nibh pharetra ultricies. Suspendisse condimentum elit nec nisl fermentum aliquam. Suspendisse porta pretium tellus, suscipit faucibus justo. Ut dignissim ex quis rhoncus imperdiet. Ut placerat ac urna in pellentesque.
If you can't dazzle them with brilliance, baffle them with bull****.
