Old 02-15-2012, 06:43 AM   #1 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
Steel rim vs hubcaps for aero
When I bought my Corolla it came with no hubcaps with fairly solid steel rims. I could put Camry hubcaps on it which look fairly good and appear to be fair aero, but was wondering what way would be less aero drag?
Camry stock hubcaps:
http://static.cargurus.com/images/si...pic-22154.jpeg
My corolla steel rims look like the ones on this car:
http://www.punny.org/wp-content/imag...0070817car.jpg
I know smooth hubcaps are best, but I'm not so sure about the moon cap look. I think I would rather clear tape (plastic maybe) camry hubcaps instead some time down the road, or maybe plastic over the steelies.
Old 02-15-2012, 06:50 AM   #2 (permalink)
tru
tru - '05 Ford Focus ZX3
90 day: 39.46 mpg (US)
the truck - '02 GMC Sierra Denali
i dont think you'll notice a difference between the steelies vs hubcaps. Moon caps would be the best, but the difference between moonies and steelies/ hubcaps i feel is slim. the advantage of the moonies probably comes into play with aggressive wheel/rim patterns that are more for looks or brake cooling.
Ive taped the holes in my steelies to not allow a transfer of air between the inside and outside of the rim and cannot tell a difference in aero / mileage benefits. I can tell a difference in brake dust accumulation. good luck with whatever you decide.
Old 02-15-2012, 09:10 AM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The smoother the better.
The lighter the better - though hubcaps won't add that much weight to the wheel.
The lightweight smooth hubcaps a lot of people on ecomodder have made for their cars, is the best choice - and often the cheapest as well.
If brake dust accumulation is an issue, you're braking too much
Old 02-15-2012, 10:24 AM   #4 (permalink)
Thanks for the input, I was thinking no hubcaps would be better on the side of being a tad bit lighter. I actually have 2 different rim styles, the second style is even more smooth with around 5-6 holes instead of the factory one with ~15. Black car, black rims, black tires, it all fits together fairly well too .
I guess I better aim for larger mods before picking all the little ones. I guess next up is the lower grill block since it is huge on my corolla.
