Old 05-24-2011, 06:20 AM   #1 (permalink)
Tracy - '00 corsa
suspect piston ring or valve clearance on my peugeot 106
hi
I suspect piston ring or valve clearance on my peugeot 106 1.5L diesel. 140,000 miles, +one year of motoring on homemade biodiesel
symptoms are: power loss, fuel efficiency loss (down to 40mpg), rough start up, slight oil leak, slight rattle noise.
i will do a compression test soon to get more information.
if it is a piston ring what are my options? i can happily put up with the symptoms if it puts off having to buy the next car. if its just one cylinder, is it possible to deactivate it by removing the glow plug and injector to that cylinder? redirect the IP fuel back into the return line or something?
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 05-24-2011, 07:40 AM   #2 (permalink)
Chug - '96 Polo CL
90 day: 49.42 mpg (US)
return lines aren't designed for that kind of pressure. if it is a piston ring, you'd probably start getting blue-er smoke out the back, check the coolant for mayo as you may have just popped the head gasket.
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 05-24-2011, 08:28 AM   #3 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Accord EX
HvyDrnkr - '93 Seville
You said that you have been running homemade biodiesel for the last year. I would also check the fuel injection system to see if something had gotten gummed up or carboned up. Pull all your injectors out and get them inspected and tested. Check everything from the tank to the pump.
Did you change out your fuel filter(s) and see if there was a performance change first?
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 05-24-2011, 10:32 AM   #4 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
+1 for fuel filters.
No longer here. Bye, and good luck to all.
Old 05-24-2011, 10:43 AM   #5 (permalink)
Chug - '96 Polo CL
reminds me - need to do that on mine when I service it before le mans
Old 05-24-2011, 02:00 PM   #6 (permalink)
Tracy - '00 corsa
yes i am changing fuel filters VERY reguarly.
Old 05-24-2011, 02:57 PM   #7 (permalink)
Have you run some regular diesel through the system with a strong cleaner? I don't know what you have available that is reputable as far as cleaners are concerned, but give it a go before tearing into the motor to rule it out. I am hoping it's something simple.
Old 05-24-2011, 04:42 PM   #8 (permalink)
Arragonis's Avatar
Team m8
I'm probably wrong but I think I heard (on a youTube video) DrDave suggesting using Bio actually released crud from your system and so you shoudl change your filters more if you use it than regular fuel.
In this case though it sounds like a comp-test may be suitable. May also be worth running the engine with your hand over the open oil filler cap and checking if you get pressure there too. If you do then the crank case is pressurised which may mean a bore / ring issue.
(Disclaimer - this is from my old classic "is my Mini a-series engine knackered or not" days...)
Old 05-24-2011, 05:53 PM   #9 (permalink)
You're right AG, forgot all about that.
Haven't you guys been running ULSD for a lot of years now?
Old 05-25-2011, 03:15 AM   #10 (permalink)
Arragonis's Avatar
Team m8
I think Euromodder posted about it in the Gas Prices thread, or some other thread about diesel fuel differences between the US the Europe. The answer I think was that EU fuel is more refined than the US variety.
Bio is available but in small quantities and not from petrol stations. I think there is/was to be a rule about a proportion of Bio being mandatory.
EDIT - Mandatory as a proportion of pump Diesel.
