Old 03-03-2008, 08:02 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Tas's 2008 Elantra Build Thread
It's not much, but there's gotta be a first step.
I installed my lower grill block this morning. I used black coroplast and tie wraps.
I didn't take a before picture, but here's a generic pic for reference.
And here's my car with the grill block.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 03-03-2008, 08:06 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
At first I was like "what grill block."
I consider that a good thing,
Old 03-03-2008, 08:18 PM   #3 (permalink)
H4MM3R's Avatar
Looks great!
Old 03-03-2008, 08:31 PM   #4 (permalink)
Moderator
The good thing is that I did not see the temp rise more than usual during my commute even though I tried to help it a bit. I'll wait till the weather gets warmer, but I'm pretty sure the upper grill opening is big enough on its own to supply what's needed.
Next in line is the abs belly pan that should come on in a month and a half when I do the 3750 miles oil change.
Old 03-04-2008, 08:13 AM   #5 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Haha, I did the same thing. Nice work Tas.
Old 03-04-2008, 08:54 AM   #6 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Great - another project thread. Subscribed!
Old 03-18-2008, 07:09 PM   #7 (permalink)
Moderator
50 cents upper grill block
Inspired by Harpo, I went ahead and blocked 3 of the 4 slots of my upper grill with black pipe insulator.
Since I completely blocked the bottom grill, all I have now for airflow is the small slot at the bottom of the upper grill. Oddly, there was not the slightest increase in engine temp vs no block at all.
Old 03-18-2008, 07:18 PM   #8 (permalink)
Moderator
Wai
The way my intake is designed, it looks like a CAI getting it's air at the front just under the hood.
The part pointing forward is just held with 2 screws and is slid in the intake duct. I figured out it would be ridiculously easy to make a WAI, so I'll give it a shot later this week.
Eventually I plan to get rid of the ribbed ducting past the MAF and delete the resonnator too to get better flow in the piping, but that'll probably wait till the warranty is over as it would not be as easy to revert back to stock compared to a WAI.
Old 03-18-2008, 07:25 PM   #9 (permalink)
Looks good. Nice, simple mod.
Old 03-19-2008, 05:55 PM   #10 (permalink)
Moderator
WAI done
5$ of aluminium ducts and 10 minutes was all it took. We'll see how my engine reacts to warmer air. I just hope that it will follow the rule that bsfc is inversely proportionnal to the square root of the suction air temperature.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1484 01-08-2012 11:12 PM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 05:31 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 01:21 AM
the "Daily Drive" thread - January 2008 drcoopster Hypermiling / EcoDriver's Ed 9 03-07-2008 01:19 PM
