Old 04-01-2010, 08:05 AM   #91 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 City iDSI EXi
90 day: 47.47 mpg (US)
Pholostan, an MPGuino or similar instant FE meter will help you, so that you know how much it is consuming at the instant, and you should be able to get back to the optimum setting where the engine is not running rich.
My bro-in-law is a engine development tester and he too pointed out the engine running rich when the throttle is floored. This is the reason why the hypermiling commandments call for say 80-85% throttle, to avoid getting the ECU turn the mixture rich. (or so I think ;-)
Old 04-03-2010, 08:04 PM   #92 (permalink)
Tracy - '00 corsa
i would think your right. there is no improvement. also think that P&G is only efficient /usefull in a large engine car. i tried it in a small engine 1L petrol and it used more fuel than normal. in small engine cars, motorway speeds require closer to wide open throttle anyway so there is no improvement.
motorway is different to city driving though and we can all benifit from not ideling the engine when DECELERATING. (EOC)
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 06:23 PM
How do you eco-drive a diesel ? groar Hypermiling / EcoDriver's Ed 105 04-03-2010 08:25 PM
Canceling out pumping losses of throttle governed engines greasemonkee EcoModding Central 60 08-03-2009 04:24 PM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
