Go Back   EcoModder Forum > AltModding > Saving@Home
Old 12-03-2009, 10:55 PM   #31 (permalink)
Connie - '00 Concours
Good Vibe-rations - '03 Vibe GT
Originally Posted by Cd View Post
Hey guys, my dad recently tried flipping the breaker for the "hot" water heater, and it works like a charm !
I live in an apartment and the water heater is gas.
Is there anything that I can do to make the water heater operate only when I need it ?
Since it is gas, I cant just flip a breaker.
( Actually, the trick would be getting to the thing, since my apartments have it behind a locked door on my porch. )
Thanks !
Heres another forum post about running a gas water heater on just the pilot light.
that post links to this article which talks about reducing the vent opening to keep more of the pilot light heat in to heat the water.
As for the locked door, you might be able to card the door if it's not a deadbolt. Failing that, since the door probably opens outward, a hammer and screwdriver applied to the hinge pins would do the trick, but be a lot more work.
Old 12-03-2009, 11:54 PM   #32 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Can you talk to your landlord about giving you access to the heater to control it, and offer to take responsibility for anything that might go wrong? That might be better than (illegally) breaking and entering a locked space that you aren't leased permission to access.
Old 12-04-2009, 12:56 PM   #33 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
That's a great idea - really !
, but it reminds me of this image. The guy that rigged this up didn't put much effort into it !
I censored the image so as not to offend anyone.
It is a great idea. I have seen small conventional 120V water heaters for RVs, as well as the common gas fired ones.
Winter daily driver, parked most days right now
Summer daily driver
Old 12-09-2009, 09:51 AM   #34 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
Chinese Water Heater? lolz
anyway, my WH has a timer
i have it set to go on at 3x in the day, for no more than 30 min/time
its good enough for 3 people
and if you ever need more, you push the button
(but dont forget to turn it off, or that sucker is on all day)
Past Present Future?
Time for New Hot Water Heater dremd Saving@Home 70 04-17-2009 04:31 PM
Electric Blanket to help reduce home heating needs? Lazarus Saving@Home 29 08-21-2008 09:21 AM
Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller) WaxyChicken Off-Topic Tech 42 08-19-2008 01:05 AM
Solar Water heater extragoode EcoModding Central 5 03-31-2008 12:54 AM
