Old 01-02-2013, 02:29 PM   #1 (permalink)
vx poor mpg at highway speeds
It seems I cant stay in lean burn at highway speeds.
If i attempt to stay in leanburn I can't keep up with traffic.
I have no problem with side streets as I can get 80mpg doing 35, I can get about 45mpg at 55 on the highway, but I cant sustain this without bumping the throttle.
Just seems like the car has a big parachute behind it
My engine is newly rebuilt (about 1000 miles on it now), tranny seems fine (~2k at 60mpg), all new tune up stuff, rolls easily, new oxygen sensor, new fuel filter, new fuel pump.. Just don't know what to check next.
Timing seems fine, valve lash fine, bald front tires
Replacing vacuum lines and PVC valve when its warmer out.
My guino tank mpg is 35. What am i missing or should recheck?
Old 01-02-2013, 04:27 PM   #2 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Some VX's had dealer option mud flaps and passenger side view mirrors that will add drag, the first VX I had had all that extra stuff and I noticed it.
Tire pressure, wider wider then stock tires, wheel alinement, to thick of oil and of course brake drag are all things that I would check.
Old 01-02-2013, 04:58 PM   #3 (permalink)
Blackfly - '98 Metro
Last 3: 70.78 mpg (US)
ForkenSwift - '92 Metro EV
Last 3: 95.68 mpg (US)
U.F.O. - '00 Insight
90 day: 95.31 mpg (US)
While you're sorting out possible mechanical issues, get a partial grille block on there as well. Every effort at drag reduction equals higher speeds before lean burn kicks out.
Latest project:Honda Insight boat tail extension (cardboard) tuft video; ABA test +9.7% Latest test: 2000 Insight: +14% MPG @ 80 km/h with 5 easy aeromods (ABA)
Old 01-02-2013, 05:35 PM   #4 (permalink)
Ryland's Avatar
The grill block might help in two ways, lean burn stops if the engine gets to cold as well, when you rebuilt your engine did you put a ~180F or a ~195 thermostat in?
The VX came with a factory grill block behind the grill, if your car did not come with A/C then the grill opening was just a few square inches.
Old 01-02-2013, 07:34 PM   #5 (permalink)
Adventurist!
CLaero - '97 CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 CR-V EX
90 day: 26.52 mpg (US)
Double check timing, too.
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
Old 01-02-2013, 07:41 PM   #6 (permalink)
Ryland's Avatar
Right... the VX cam shaft timing is not set with the pulley marks inline with the head, instead it's set with the pulley marks inline with another set of marks on the head that are about 6 degrees off.
The Following User Says Thank You to Ryland For This Useful Post:
slownugly (01-02-2013)
Old 01-03-2013, 12:31 AM   #7 (permalink)
thanks, i'll start checking things.
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
