Old 11-21-2013, 02:26 PM   #1 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.3 mpg (US)
Weather Recording
Well, with Winter upon us, it seems that it will be more difficult to fully understand what any one mod is doing from tank to tank. I found this weather website which gives you historical information and you can change the dates for whatever your tank was.
Weather Underground History
Put your zip code, a date and then after submitting, click custom to put whatever dates you want. You can get max, min and mean temperatures and a whole bunch of other information.
Obviously, it won't be a direct correlation to mpg results, but it can help to show why mpg might be lower (or higher) than a previous tank.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
The Following 2 Users Say Thank You to jeff88 For This Useful Post:
101Volts (11-21-2013), pgfpro (11-21-2013)
Old 11-21-2013, 03:37 PM   #2 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
Or just buy a Kestrel meter and keep track of it yourself.
I record DA(density altitude) and RAD(relative air density) for each tank.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 11-21-2013, 03:48 PM   #3 (permalink)
Lots of Questions
I have to admit, I hadn't heard of one of those before, but after seeing a pic, I have seen them before.
When I get around to putting an Arduino in my car, I want to put a sort of weather station. I'll have to look into something like this that'll work.
I really like the idea of measuring density, better than just warmer/colder air.
Best EM Quotes:
Old 11-22-2013, 10:10 AM   #4 (permalink)
Spreads I've seen so far-
DA- -1500ft to +4700ft
RAD- 89%-104.5%
Air Density- .069 - .08 lbs/ft3
