Old 07-17-2008, 10:39 PM   #1 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Where to buy vortex generator fins?
Hi y'all,
I have been contemplating how to improve the trailing aerodynamics of my hatchback xA -- and on the commute home this evening, I saw a (apparent) race car on a trailer. It was a Mitsubishi sedan, with some low profile tires and a large (functional?) wing on the back -- some sort of SCAA racer, maybe?
Anyway, it had a row of small vortex generating fins along above the rear window -- I want to know if these are available to buy from someplace?
Old 07-17-2008, 10:48 PM   #2 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
The Mitsubishi Evo and Subaru STI have functional vortex generators on their roofs, because they act to put the giant park-bench wings into airflow, making them work better at generating downforce (and drag).
It's been posted elsewhere here, but Mitsubishi put out a paper on their VG design.
You can probably buy ricer-ready knockoffs without half-trying, or spend the money on the real thing from Mitsubishi or Subaru (and have them probably be nearly as ineffective as the cheap knockoffs, because your car wasn't designed for them).
Google shopping results for 'evo vortex generator'
evo vortex generator - Google Product Search
Old 07-17-2008, 11:02 PM   #3 (permalink)
Josepha - '08 xD
Okay,
Then, is there another type of aerodynamic device that could clean up the trailing air flow on a hatchback? Those tabs that are used on semi trucks look a little too difficult to pull off...
Old 07-17-2008, 11:15 PM   #4 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
The tabs from Airtab don't look too bad to remove (attached w/ either 2-sided tape or glue) but they do stand out and are a bit of an eyesore. However, I am very intrigued by the testimonials and their wind tunnel video. Could be worth checking.
www.airtab.com - The smart way to cut the cost of your highway fuel costs
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-17-2008, 11:26 PM   #5 (permalink)
Bio Deezler - '03 Jetta GLS TDI
90 day: 50.78 mpg (US)
Try these, and do a scientific investigation of fe benefits. (be the guinea pig)
Welcome to Vortekz.com
Old 07-18-2008, 12:12 AM   #6 (permalink)
Josepha - '08 xD
Hello,
The AirTabs are $200 (for a set of 80!) or $2.50 each, and the Vortekz are $20 (for a set of 10). I'm thinking of 2 sets of the Vortekz...10 for the roof, and 5 on each side, or maybe 3 sets...here's what they look like:
Now that I think about it, the AirTabs are $25/10 and they are larger, so...I dunno yet.
Old 07-18-2008, 12:59 AM   #7 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
Last 3: 58.02 mpg (US)
I used a template off of gas-savers and they work amazing. About 30 min of work to make way more then I needed and scrap so no cost.
They are being only held on by painters tape to determine the final position via tuft testing.
I like Vg's and my i'll post up my first tank results later tonight but its my best tank yet, 515 miles with little under 1/8th tank left.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 07-18-2008, 05:20 AM   #8 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
NeilBlanchard -
I have Airtabs. I was worried that I wouldn't like the aesthetics either, so I made them reversible. I used business card magnets :
Then I put a strategic Neodymium magnet in the interior volume :
I haven't lost one since I installed them in March. I only take them off if I am going to wash the car. If I do lose any/all of them, I will probably get more and make them permanent because now I "like" the look.
CarloSW2
American Solar Energy Society
Old 07-18-2008, 08:23 AM   #9 (permalink)
Josepha - '08 xD
Hi Carlo,
And -- how do they work?
Old 07-18-2008, 10:18 AM   #10 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
I've seen a few threads about these, but nobody seems to want to run a test.
fins, generator, vortex
Another Vortex Generator Application? jerm1978 Aerodynamics 14 02-19-2009 08:52 PM
Honda's OEM vortex generators ... on the Ridgeline pickup mirrors MetroMPG Aerodynamics 21 12-06-2008 02:09 PM
If your car died, what would you buy? rjacob EcoModding Central 56 08-02-2008 02:42 PM
Is guaranteed 3$/gallon gas worth enough to buy a Chrysler? SVOboy General Efficiency Discussion 29 07-25-2008 07:54 PM
