Old 10-17-2008, 10:55 PM   #171 (permalink)
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
90 day: 32.54 mpg (US)
F150 - '94 F150 XLT
90 day: 17.21 mpg (US)
Sport Coupe - '92 Tempo GL
Stupid $15 facilities charge is half my bill!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 10-18-2008, 12:32 AM   #172 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Frank,
yes that is stupid
the "facilities charge" should be pro rated per kWh
like I said before
I would be happy if we could just stop distorting the market
that is a rather regressive system that almost subsidizes non conservation
you just got notice?
is the rate set for sure or is just set to go for approval?
(around here you usually get a shot a contesting such moves before the are set in motion)
Concrete
Start where you are - Use what you have - Do what you can.
Old 10-18-2008, 12:41 PM   #173 (permalink)
Nice Road Trucker
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 26.31 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 20.42 mpg (US)
"Facility charge" or the same thing by other names reflect the fixed charge of power T&D regardless of usage. That transformer and transmission line cost exactly the same whether you use zeo kwh or up tro the capacity of the line. Actaully the 240 volt residential service is an expensive way to transmit power. Generally the higher the voltage at which you recive the power the less T&D losses are incurred. Big users receive power at high voltage (often 13.2 kv) and have their own substations, and thus the did not get billed for a "facility charge."
On the macro scale, wind, solar, and geothermal electrucity are penned into limited geographical areas simply because that's where they are. Maybe (with a massivel augmented T&D infrastructure) the parts of America west of the 100 meridian maybe could be substantially powered by solar (roof over Nevada and Arizona), wind (the Front Range Ridge is an awesome potential resource) and geothermal (Yellowstone alone could be substantial).
But solar in South Bend? Wind in the Ohio Valley? Aintgonnahappen.com
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam 3.08:1 gears
"Fastback" Bed Fairing
Rugged Air Dam
Old 10-18-2008, 08:03 PM   #174 (permalink)
PA32R's Avatar
LR3 - '06 LR3 HSE
Originally Posted by trebuchet03 View Post
It's worth pointing out that these large bladed designs have really high tip velocities.... Which leads to an unfortunate limitation of scale as you get nearer to the sound barrier.
High Altitude It's the future
At 28.8 r.p.m. you can have a blade diameter of almost 110 meters and have a tip speed of less then mach 0.5. That's a pretty big fan. I suspect stresses might be a problem on a thin airfoil 54 meters long. The A380 wingspan is
not quite 80 meters, so the wing itself might be about 37 meters. I'm not sure about the stress calculations for a wind turbine blade, but I'm guessing that that's the limiting factor. From what I can see googling around, it looks like 100 meter turbines with 49 meter blades are the upper end at this time. Tip speed would be well below mach 0.5 at 28.8 r.p.m.
Here is a picture of a huge turbine with rotor diameter of 126 meters and blade length of 61.5 meters. At 28.8 r.p.m, the tip speed would be about 190 meters/second or a little under mach 0.6. Transonic speed is considered to begin at mach 0.8. So, there is some room to grow.
Old 10-19-2008, 10:04 AM   #175 (permalink)
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.98 mpg (US)
The Van - '00 Odyssey EX
90 day: 21.08 mpg (US)
But compressibility effects in fluid dynamics begin to become significant at or below M0.3 IIRC from my own courses in turbomachinery design and fluid dynamics.
Your aircraft wingspan analogy ignores that in an airplane the lifting force is roughly perpendicular to the direction of motion whereas in a turbine the lift force is tangential to the direction of motion. This has significant influence on the available cross-sections to resist the bending moment. A turbine blade can have a much larger supporting base in the direction of loading to improve its section modulus without negatively impacting its drag ratio. This is simply not as practical in aircraft.
Old 10-19-2008, 02:07 PM   #176 (permalink)
Nice Road Trucker
Big Dave's Avatar
How much loss in efficiency of your wind turbine is a bird worth?
Rugged Air Dam
Old 10-19-2008, 02:41 PM   #177 (permalink)
Sequential
Concrete's Avatar
Question ????
Dave,
I'm confused
in this case the larger wind turbines are:
more powerful
more efficient
more cost effective
and less likely to kill birds
not sure I understand your question
and I know you are not advocating chopping down turbines because of government regulations on birds
Concrete
Old 10-19-2008, 07:33 PM   #178 (permalink)
Nice Road Trucker
Big Dave's Avatar
They may or may not be improved but they are still subject to project-delay lawsuits.
Rugged Air Dam
Old 10-19-2008, 09:27 PM   #179 (permalink)
Sequential
Concrete's Avatar
Dave,
I think birds are yesterdays lawsuit
the tree-huggers have moved on to bats
Bats More At Risk From Wind Turbines Than Birds, Study Claims : TreeHugger
you know, all kidding aside
the tree huggers have harassed all the renewable sources of power
The cartoon that started this thread was a joke that "the man" stops renewable energy
but your point Dave is a documented fact:
tree huggers are as responsible as any faction for "Why we have no wind or solar power"
Concrete
Old 10-19-2008, 11:19 PM   #180 (permalink)
This was timely, people in high places think this is a potential problem.
Gas pipelines vulnerable to terrorism: expert : Home : News : Sympatico / MSN
Converting power steering to electric power steering Daox EcoModding Central 29 02-02-2010 04:04 PM
Without Clean Electricity, Plug-In Vehicles Aren’t So Hot SVOboy General Efficiency Discussion 37 10-17-2008 02:35 AM
Wind Power trikkonceptz Fossil Fuel Free 13 10-09-2008 01:32 AM
Wind power testing idea extragoode Saving@Home 5 08-21-2008 12:09 PM
Bullfrog Power wind farm owner dumps his Insight for a Prius MetroMPG General Efficiency Discussion 0 12-16-2007 11:50 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
