Go Back   EcoModder Forum > Classifieds > For Sale
Old 10-02-2008, 08:34 PM   #1 (permalink)
Zemco Compucruise 44 New In Box...
I was looking for a Compucruise trip computer for my 1986 Tercel wagon, and bought out the stash of a Zemco dealer from the 80s. If you have a carbureted car, and want a trip computer for instant feedback on fuel consumption, here you go. Features include:
Clock
Elapsed Time
Stopwatch
Trip Time
ETA
Alarm (wakeup or reminder)
Distance Traveled (miles or KM)
Distance Till Arrival (miles or KM)
Distance Till Empty (miles or KM)
Fuel Used Since Fillup (gallons or liters)
Fuel Used on Trip (gallons or liters)
Fuel to Arrival (gallons or liters)
Fuel to Empty (gallons or liters)
Current Vehicle Speed (MPH or KPH)
Average Vehicle Speed for Trip (mph or KPH)
Current Fuel Consumption (GPH or LPH)
Average Fuel Consumption for Trip (GPH or LPH)
Current Fuel Efficiency (MPG or L/100 KM)
Average Fuel Efficiency for Trip (MPG or L/100 KM)
Inside Temperature (F or C)
Outside Temperature or Coolant Temperature (F or C)
Battery Voltage (volts)
Cruise Control (digitally input speed)
Cruise Control (engage at current speed)
Cruise Control (resume)
Night Time Display Dimmer
The price is $150 plus shipping, and the kit is brand new in the box from the 80's. The kit is made for a carbureted RWD car. If you have a FWD car and need the extra sensor kit, I'll include one for an additional $5. I don't have any of the fuel injection interfaces, but from what I've read, they're not hard to build. This was one of the best aftermarket trip computers ever built, and they're getting about impossible to find brand new in the box.
Old 10-05-2008, 04:07 PM   #2 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
I have one of the older versions before they had cruise. I have replaced a few things over the years and still have it installed on a rabbit diesel to this day. I found that a modern cam/crank position sensor works well to pickup the six bolts that hold on my front drive shaft. The recirculating ball has been replaced with a .12 gram competition plastic BB. And the light source in the flow meter has been replaced with a white LED. Those are the only things that I have replaced in almost 30 years.
Old 10-08-2008, 04:20 AM   #3 (permalink)
I'm going to install mine with a speed pulse generator in a two-piece speedometer cable. I'm also using a vacuum servo and the relays from an A-R-A cruise that was made specifically for my car. That setup will allow me to mount the servo under the dash to work directly on an arm bolted to the top of the accelerator pedal. The only part mounted under the hood will be the two relays and their bracket. I need all the room I can free up to mount the tank for my Waag-Injection kit.
Old 11-01-2008, 05:10 PM   #4 (permalink)
Zempco Compucuise
Hello, will this unit work with 1989 Honda Accord LX1 2.0 liter fuel injected engine? Please advise, thank you...James
Old 11-01-2008, 06:19 PM   #5 (permalink)
Not without an interface box for the fuel injection, and they're impossible to find. I know a guy who has the schematic if you want to build the interface.
Old 11-01-2008, 07:02 PM   #6 (permalink)
Great, can you send me the info so I may contact this guy with the schematic, thank you...James
Old 11-03-2008, 01:32 PM   #7 (permalink)
When I get the schematic from the guy you know I will then be able to build the interface, thank you...James
Old 04-17-2009, 06:45 PM   #8 (permalink)
68.9 mpg best trip
Mercedes 89 D - '89 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Octavia TDI PD
90 day: 42.04 mpg (US)
Send a message via Skype™ to oldbeaver
Thumbs up I like your Zemco. Questions
Dear,
It is probable that you have what I want. A trip computer for carburated engines. However, I need it for a diesel engine, year 1995, non electronic.
Then, I need the extra sensor.
However, before purchasing it, I need more info, as to ensure it will serve my purposes.
For instance: will the fuel flow sensor work? Are are they designed to deal with fuel flow sensing?
Thank you very much,
Old Beaver
Clock
Elapsed Time
Stopwatch
Trip Time
ETA
Old 04-17-2009, 09:14 PM   #9 (permalink)
As described, this is designed for a carbureted engine, and diesels don't use carburetors. Any adaptation work that this would require would be at your own risk. I've listed everything I know about this unit.
Old 04-18-2009, 02:35 PM   #10 (permalink)
68.9 mpg best trip
Smile Zemco Trip Computer
Dear,
I understood that you said for a front wheel drive car the Zemco will need an extra sensor.
What I need to know is how the Zemco 44 TC connects to a carburated engine. If you can scan the connections diagram, I will know if I take the risk or not.
At last, "a carburated engine" means a non-injected engine, that is, the fuel flow sensors are not attached to injectors. That is exactly what I need: to sense the fuel flow somewhere else. It probably uses mechanic flow sensor, and that is what I need.
If you do not want to send me more info about the Zemco 44, then please tell me about the fuel flow sensors it uses, and where can I get them. Just give me the brand and model. Of course a picture will be a useful complement.
Thank you in advance for sharing that info with me.
