Old 10-12-2016, 04:37 PM   #1 (permalink)
Delta Flyer - '94 Honda Accord
90 day: 31.31 mpg (US)
Aero My Accord??
Hey guys,
Hello! New here and eager to get started!
I'd like to do some aero mods on my 1994 Accord. So far I have some grill blocks. I used to have a partial undertray but i removed it to do some work. I'd be interested in mods that would give the best improvement in gas mileage. (So far 30 mpg is my record, and that's with trying to hypermile.)
Thanks,
Road Cyclist
Old 10-12-2016, 05:53 PM   #2 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
Felicia - '09 Toyota Prius Base
90 day: 49.47 mpg (US)
Howdy,
Go ahead and introduce yourself on the Introductions page.
Start a Garage page for your Accord. Being able to track your results is huge.
My recommendation just for starters: put that belly pan back.
Old 10-13-2016, 10:35 AM   #3 (permalink)
I'm having trouble getting pictures up...
Old 10-13-2016, 10:37 AM   #4 (permalink)
Here's a link...
Mobile Uploads by Fake62 | Photobucket
Old 10-13-2016, 11:05 AM   #5 (permalink)
Master Novice
elhigh's Avatar
You should be able to include pix now that you have >5 posts.
Grille block looks pretty sharp. Any air damming going on, or did you skip that in favor of the belly pan? I can't tell because the picture is small, I'm old and my eyes have been crap since second grade.
Old 10-13-2016, 11:25 AM   #6 (permalink)
Sorry for the pic... No air dam yet. I have pipe insulation on the bottom and cardboard on the top grill.
Seems like an air dam and an undertray can't be used at the same time... am i wrong?
The Following User Says Thank You to RoadCyclist For This Useful Post:
aerohead (10-15-2016)
Old 10-13-2016, 01:57 PM   #7 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
They can, but they both address the same problem. A dam diverts are from a problem area, whereas a pan makes the area less problematic.
I recommend you start here: 65+ Vehicle modifications for better fuel economy - EcoModder.com
Old 10-13-2016, 02:09 PM   #8 (permalink)
I've read that... which do you recommend, a dam or tray?
Old 10-13-2016, 02:10 PM   #9 (permalink)
The tray is a lot more work but will offer greater returns. I have one on my car.
Old 10-13-2016, 02:25 PM   #10 (permalink)
Master Novice
elhigh's Avatar
You can install an airdam in a few minutes for a few bucks that will make a positive difference on your fuel economy.
You can install a belly pan in a few hours for a lot more bucks that will make a bigger difference.
I read from someone else that you could get about 80% of a full belly pan's benefit with a well-executed air dam, for a fraction of the pan's cost. Seeing how I have neither, I have no actual experience to speak from, I'm only repeating the wisdom of others.
One thing I have wondered is whether there is a benefit to be had by doing both. In the case of a fully panned car, I strongly doubt you would need as much dam.
