Old 01-23-2021, 04:05 PM   #1 (permalink)
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 38.87 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 30.42 mpg (US)
Toyota Auris Build Thread
Toyota Auris has completely the same powertrain as Prius III and same baseline specification. I will try to express all the mods and DIYs in this thread.
Current Mods:
1. CD-drive removal: -470g.
2. Number brackets removal: -300g.
3. Seat rails rear covers: -142g.
4. Lower grill block (winter only, workaround).
5. Extra towing hook removal: -570g.
6. Switch 16 OEM wheels to 15 Honda: -12.000kg.
7. Switch 205/55R16 Bridgestone to 195/65R15 Dunlop: -9.640kg.
8. Lightweight lug nuts: -0.769kg.
9. Rear speakers removal (both sides): -420g.
10. Rear headrest (middle only) + supports/locks: -374g.
11. FM antenna removal: -369g.
12. Spare tire: -14.600kg.
13. Rear middle seat-belt and lock: -815g.
TOTAL: -40.469kg.
Old 01-23-2021, 04:12 PM   #2 (permalink)
alexshock's Avatar
My focus for the nearest time is weight saving.
So... I have extracted a CD drive from the headunit (yes, it is not a joke).
Weight reduction is -470g.
The Following User Says Thank You to alexshock For This Useful Post:
Nathan jones (06-25-2022)
Old 01-23-2021, 05:00 PM   #3 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I haven't seen the sig in a while and forget whose it was, but "Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce."
Every bit helps!
Transmission type Efficiency
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
alexshock (01-24-2021), Ecky (01-23-2021)
Old 01-23-2021, 06:38 PM   #4 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
It's a start. What sorts of things do you plan to remove? Back seats? Sound dampening? Interior trim?
Most of my driving is steady-speed, so weight removal isn't hugely beneficial for me, but if nothing else it could make the care more spritely.
Old 01-24-2021, 06:17 AM   #5 (permalink)
alexshock's Avatar
I'm going to keep back seats, definitely... Some times they are still in use
I will try to keep balance between mpg and comfort as long as I can. I'm trying to build something that is called "sleeper" in automotive culture.
So, here are few plans for the nearest future:
1. Rear speakers.
2. Wheels.
3. Some useless interior trims.
4. Rear middle seat-belt.
5. May be some sound dampening - I'm still in doubts, as in current state it is pretty comfortable.
Old 01-24-2021, 02:47 PM   #6 (permalink)
alexshock's Avatar
This is an old mod... did it 2 or 3 years ago.
Removed number plates brackets and attached number plates directly to the bumper.
At that time I was not concerned about weight reduction, so I have no information about real weight of a single bracket. But brief search on the Internet shows 150g per one bracket of the same model. So, it is 300g in total.
ID:	30055   Click image for larger version
Old 01-24-2021, 03:02 PM   #7 (permalink)
alexshock's Avatar
Yet another old mod: removed rear covers of front seats' rails.
I found that rear and front covers are different... Front covers fit fine and tight. Rear covers look terrible and actually very loose (poor design...). Also, they should protect from rear passengers, but I found that with almost no passengers and with covers there is still some stain on the back side of rails... useless.
Weight effect: -142g.
ID:	30057   Click image for larger version
Old 01-26-2021, 09:33 AM   #8 (permalink)
alexshock's Avatar
Installed 100% grill cover on the lower grill (engine). Upper grill (inverter) will be open.
Ecky (01-26-2021)
Old 01-27-2021, 03:26 AM   #9 (permalink)
Nice work. Keep us posted.
The Following User Says Thank You to mattrod For This Useful Post:
alexshock (01-27-2021)
Old 02-09-2021, 11:27 AM   #10 (permalink)
alexshock's Avatar
So... Wheels!
This is a research post, not a mod, because I have not yet installed anything.
Despite identical powertrain, Auris has different chassis comparing to Prius. So, I cannot blindly apply "best practices" from PriusChat - I need to do my own research.
Factory tyres are 205x55x16, Bridgestone Turanza ER300.
For some reasons, they are extremely heavy, like run-flats. There are several different variants in my size, current setup weights 9.96 kg per corner. While any other tyres including other variants of ER300 are between 8-9 kg. I have sold them already while currently driving winter tyres.
Wheels have size of 16x6.5j, ET 45mm, bolt pattern is 5x114.3mm, center bore is 60.1mm.
Factory wheel weight is 10.0 kg per corner!!! Which is extremely heavy for normal 16in wheels.
Like everyone, I want to buy a set of RPF1 but I will not...
In my size they weight 6.2 kg - cool, I could save 3.8 kg per corner.
1. They are expensive, especially taking into account delivery into my region (no local dealer/importer). May cost up to USD 1500 per set (wheels + delivery).
2. They are wider... still fit factory tires, but I want to gain some aero also. This is a good option for city driving, but not for interstate roads.
ID:	30140   Click image for larger version
ID:	30141   Click image for larger version
ID:	30142   Click image for larger version
