Well, consider mine removed: loosened 2-12mm bolts, a wingnut tension assist, and it slipped right off. I'm leaving the wrench and belt in the car in case I need to install it quickly.
Tomorrow's commute will tell the tale.
(wondering why I didn't do it sooner)...
EDIT: So, what kind of FE boost am I looking at (in addition to the health benefits of a workout to park)? It's been a while since the actual value was discussed...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
 _
 _
Reason: % Inquiry
