Old 09-14-2009, 02:46 AM   #56 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Wow. You guys have been busy.
I like the simplicity of the click things. It's an all in one solution, minus shift box. The only thing would be the programming which is totally out of my realm. I could fab the microswitch shifter in my sleep (would rather mod an existing stick) and wire the relays and resistors but the whole math/logic/progarmming is all Greek to me.
I will take a closer look to see if it's user friendly or not when I get some time.
I have to crawl under the egg to see about the neutral shift linkage. I remember seeing a lever and cogs when I was changing the ATF. I think neutral is mechanical. Not insurmountable but trickier.
I don't want the paddle shift or triptonic type because I need to be freer to jump between gears after EOC. Are we looking at a shifter on a shifter?
Then of course there's reverse.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
