Old 09-27-2009, 07:18 AM   #1 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Stiffener bar for soft front aero deflector
Installed aluminum stiffener bar for aero deflector that's at rear of the front bumper cover. This is the one that flops around a bit, has a formed notch for the exhaust downpipe. Attached with alum. pop rivets. Stiffener is on top side.
I used a bit of aluminum angle stock that was originally for flooring installation. Is like angle iron except the raised side of the angle is only about 3/16 inch, not equal to the width of the other 'leg' of the stock.
Watch out for bracket at lower corner of radiator, drivers side - the bar was hitting it so I added some foam pipe insulation for padding held in place with duct tape. Would have been better to grind away a bit of the new bar's material before riveting into place.
Coast long and prosper.
