Old 10-13-2009, 02:06 PM   #20 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Torque converter lockup switch.
Turns your auto into a manumatic. Takes some getting used to but the benefits are there. Just getting data together now. These are used for towing where the auto can overheat, the TCC lock switch overrides the ECT and lets you lock up on demand. Mine took ten minutes to wire. I can lock up at any time (RPM permitting) in any gear except first.
http://ecomodder.com/forum/showthrea...tch-10028.html
Also on Toyotas (and possibly other cars) there is a kickdown cable which should be tightened to give faster shifting and higher fluid pressure. Reduces wear on the tranny and (I think) a more secure TCC lock.
The Free Mod Series - Part I Quicker Transmission Shifting - Toyota Forums :: Toyota Nation
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
