Thread: NarrowerTires?
Old 11-24-2009, 03:34 PM   #5 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
There will be a small but real aerodynamic benefit from going with narrower tires as well.
See this BMW data: http://ecomodder.com/forum/showthrea...g-cd-7475.html
Will 155's fit properly on the rims (width)?
In "the realm of safety", as you put it, I expect you'll likely see reduced lateral grip in the dry (not certain about wet - depends on many other factors). Whether you're OK with that is up to you.
