Old 03-14-2008, 05:38 PM   #15 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by s2man View Post
Shoot. I thought you already had that working.
I really researched it a while back and actually got started on it. The hardest part was finding cool air high-enough in the body of the vehicle to avoid the potential of sucking-in water. I got busy with other projects and gave up
I'm half-tempted to remove the passenger-side high-beam a-la racer style . I've heard of trimming the turn signal to allow an air inlet. The problem is the plumbing for the A/C and coolant lines are all in that area.
Instead of a complex, electronic system, I might develop some sort of manual, in-cabin cable system to change or mix intake air.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
