Old 12-01-2009, 10:02 PM   #32 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Sorry, joining the party late...
Originally Posted by jedi_sol View Post
In my old kammback thread, I was told the transition should be 10* to keep attached airflow.
That's a rule of thumb for the initial transition. If you taper gradually (ie curve), you can apparently go up to 22* with attached flow (assuming the upstream flow is clean).
Also, I was told by MetroMPG that the transition from the top to the side should be rounded, which i haven't figured out yet. Otherwise (correct me if im wrong MetroMPG) it would create vortices (spelling?) in that area.
Yes. The images Cd made would yield better results than the initial mockup - glad to hear those are being copied. You want an organic shape so pressure recovery is gradual, not hard corners which could trip the flow and cause early separation.
The exception is the very rear surface (what I call the transom - where the tail lights go). You can chop that off clean and have hard corners there.
