Nice block Daox, I'm fixing to do mine soon too. Although the aesthetics inspector will probably want it on the inside. I may be able to get away with a plexi one though.
You might look at hacking a temperature reading from the inverter coolant loop. The first little radiator in front of the vehicle radiator is the inverter coolant loop.
Where is the OAT sensor located on my 2003? When I return the Graham scanner, I would like to do that hack.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
