a lot of times, several studies are comissioned but only the favourable ones are published. Would be interesting to see other studies on this.
I like how they compare it to a chainsaw and an intersection in terms of quantity of pollution.
http://www.aboutmyplanet.com/environ...drive-through/
Some numbers there about idling. If someone could do the math and compare these numbers to a warm start I bet you'd still find stopping uses less and emits less.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
