Originally Posted by RobertSmalls
I think the right way to do that in the CVT is with gentle action on the skinny pedal, so as to keep RPM's down.
Off topic: the 2010 Insight's "EV mode" still has the gas engine rotating, but with all 8 valves closed to reduce, but not eliminate, frictional losses in the engine.
To continue off-topic (briefly) I have been searching for more details (without success) on how this engine works. Is there a good source you recommend? Thx...
RH77
