Old 01-10-2010, 07:16 PM   #8 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
EV-Only Mode
I discovered a way to run in "EV" mode pretty easily.
At speeds greater than ~11 MPH, lifting the accelerator, then very lightly applying throttle evokes power from the battery only. There is some drag from the engine as it maintains compression, with the valves in the closed position, but downhill runs or efficient deceleration can be manipulated.
I haven't found much at all on driving this vehicle efficiently (or the highly technical aspects), so the plan is to compile some methods and information as a primer in developing a separate thread.
Other HI-2 owners are welcomed to add any info...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
