OK this is funny:
"Welcome to the WORLD OF TOMORROW!"
The body styling of the PULSE gives it a fantastic futuristic look, at the same time following form with function. The aerodynamic shape allows the vehicle to cut through the wind and results in unusually high fuel mileage and performance. The PULSE has ten (10) times less drag than a motorcycle and its rider. The body is also designed in such a way as to increase stability and directional control as speed increases. The drag coefficient is .193
From here:
http://www.autocycles.org/index.html
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
