Old 01-28-2010, 12:53 PM   #10 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Turned out excellent. Was about 4 years ago and is still holding up well. I heard that headliners fail from moisture. So I figured both contact cement and polar fleece are waterproof, so it should hold up well.
After removing the board and old material, I used a stiff plastic bristle brush to remove the old foam remnants. Then I filled all the pits and and rebuilt the broken corners with fiberglass body filler. I also used this opportunity to reverse my dome light which makes more sense with the spotlights now to the rear.
Then I applied like 2 or 3 cans of contact cement to the board with a roller, enough to saturate it pretty well. Then I laid down the fabric and pressed it in with a clean roller.
Anybody who sees it really likes it.
Winter daily driver, parked most days right now
Summer daily driver
