Old 02-15-2010, 07:35 PM   #125 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
#2 is being addressed by using the EGR cooler though. So, I think #1 is going to be the main problem.
Would a higher-octane fuel help with the detonation (or be cost-effective)? I run 91 octane with the higher coolant / IA temps, and advanced timing -- usually 20/cents more per gallon can be a good investment.
(I'm still trying to figure out if the Integra has an EGR valve -- the shop manual is contradictory).
Great research so far -- I look forward to more results
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
