Old 03-01-2010, 03:10 PM   #24 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
That is a nice thing about well designed belly pan/rear diffuser. It doesn't really change the appearance of the car.
FWIW, I replaced the plastic lower engine cover with an aluminum skidplate and added coroplast extensions in front of the front tires. Perhaps a used Mk IV engine cover could be modified for a Mk III?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
