Old 03-28-2010, 08:33 AM   #49 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Some more specs of the "XFE" version of the Cruze have been released.
First off, they're not calling it the "XFE". It's the Cruze Eco.
Second, they're sticking to their guns: 40 mpg highway, and "expected to deliver the best fuel economy in the compact segment."
The axle ratio on the manual-transmission model is also optimized for fuel economy, while helping the car deliver confident performance.
Chevrolet estimates the Cruze Eco will deliver 0-60 mph performance of about 10 seconds with the manual transmission and 9 seconds with the six-speed automatic. Featuring an Ecotec 1.4L turbocharged engine with variable valve timing, the Cruze Eco is designed to be the most fuel-efficient model in the lineup, delivering an estimated 40 mpg on the highway with the standard six-speed manual transmission. City fuel economy, as well as estimates for the Cruze Eco equipped with an available six-speed automatic transmission, will be finalized closer to launch.
The Eco achieves greater fuel economy using a number of features that enhance its aerodynamics, minimize weight and reduce rolling resistance. Details include:
  • A lower front grille air shutter that closes at higher speeds to improve aerodynamics and opens at lower speeds to optimize engine-cooling airflow
  • The upper grille has more "closeouts" to improve aerodynamics
  • A lower front air dam extension, extensive use of underbody panels and a rear spoiler enhance aerodynamics
  • A lowered ride height improves aerodynamics
  • Unique 17-inch lightweight aluminum wheels
  • Ultra-low rolling resistance 17-inch Goodyear tires.
The Cruze Eco will be available in the fourth quarter of 2010.
