Old 04-02-2010, 09:59 PM   #29 (permalink)
k.civic.f4i
recession proof rebel
k.civic.f4i's Avatar
cfg83 was referring to me in one of the earlier posts. i basically did what was in that video except i didn't use wood. i bent a thin piece of plastic, used double-sided tape to keep the contour and started to fiberglass a piece so that it would fit perfectly in the fog light indentation. it is very time consuming.... mostly because it takes forever for fiberglass resin to dry.
tomo did the foam spray method and it seems to have worked for him. a small opening for the radiator is enough for our little civics.
if youre going to use my method, you should do it in coroplast or cardboard first to get a template anyway. then see if you've blocked off too much. this way you can alter the template before the fiberglass work.
how to's in my signature
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
