Old 04-19-2010, 12:28 PM   #4 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
My $.02
Mods:
Grille block
Smooth wheel covers
Block heater
Rear wheel skirts
Technique:
Practice using your ICE/brakes/regen the least by timing lights and coasting as much as possible. I use neutral coast a lot at city speeds.
and learning how to keep it running in EV mode as much as possible, will help a lot, too.
With respect to Neil, this is a bit of a misconception.
Actually, unless you have a plug in, you want to avoid using EV and try to P&G using the ICE instead. Use up extra battery energy if you have regenned it but avoid having the ICE charge the battery directly because of the efficiency losses.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following User Says Thank You to orange4boy For This Useful Post:
Daox (04-19-2010)
