Old 04-29-2010, 03:59 PM   #1 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Stainless Kammback for Previa Redux. Now With More Stainless!
I had a the inspiration to work on the kammback or partial boattail, if you will, a couple of days ago.
The top part is now finished except for closing off the end. I cut new trailing edge pieces and extended the lower section rearward to make the end angled instead of vertical as it was in the prototype.
I also slightly reduced the inward angle of the sides as they were somewhere around 20˚ which is fine if all is perfect. I think it looks miles better now and the wake should be a bit smaller. The top piece of lexan is unchanged.
I'm still thinking about how to finish the bottom section. I would like to be able to use it for storage but it should be easily removed and light weight. More thinking required.
It's only a little bit heavier now but I need new struts. I have to prop it up to keep the back open. New struts should hold it up fine.
The prototype for comparison:
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following 3 Users Say Thank You to orange4boy For This Useful Post:
NeilBlanchard (04-29-2010), Piwoslaw (04-30-2010), Rokeby (04-29-2010)
