Old 05-01-2010, 01:04 AM   #3 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
You do need to make sure there is some airflow through the rad. In the winter you might get away with a full block. You need to leave an opening in your grille and in the belly pan. You can experiment with the grille by changing the block till it does not overheat. The best way would be to have a good size opening in your belly and change the rad block till optimal. Or if you are inventive, an adjustable grille block.
Is your rad fan working?
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
