knock yourself out.
5 times the wieght per sq foot. Waves will accomplish nothing. Need many more mounting points.........did I say tooooo heavy.
Look, take a look at the underside of the audi 2011 A8. they use abs plastic not metal.
look at the underside of ANY top end car SLR Mercedes etc. They are using the LIGHTEST possible material.
THere was a guy that wanted to use skid plate because the little bumps could work as reverse dimples. SKID PLATE!!!! under the whole car!!!!
You really have to use the lightest material possible......
