Originally Posted by dcb
I would wait till you are bit on the guino speculation  If the injectors are not getting power then neither is the guino injector signal.
dcb,
I'm sorry I don't get what you're saying about "wait till you are bit on the guino speculation". I'm sure I'm just being obtuse but hmmm??
BTW I do have the guino pretty well calibrated. Did distance with a GPS. Fuel qty is good enough now that a 9.4 gal fillup was only off by about .05 gal. I put in the correcion for that so hopefully next fillup will be even closer.
