Old 05-23-2010, 06:28 PM   #11 (permalink)
Hyperlurker
daring4's Avatar
D-max - '04 Chevy Silverado Ls
Notch - '65 Volkswagen 1500 S
MTCHBX - '05 Scion XB
90 day: 40.41 mpg (US)
I bet your fuel injection is more advanced than the old Fiero! All my injectors fire at the same time, yours are controlled independantly I assume.
Old 05-23-2010, 11:04 PM   #12 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Found the inj. power wire.
It's in the connector in photo but not the fat yellow + black wire noted earlier.
It's yellow + black, the top position, center column (as shown in photo with connector clipped to bracket).
daring4, yes, I'm pretty sure the injectors are individually controlled both for timing and maybe also duration, attempting to adjust qty per cylinder to keep it smooth??
Now - from dcb's post, I'm reminded that cutting the 12V power to injectors will NOT be directly noticed as fuel cut by the 'Guino because it reads the ground side of the inj circuit. So after fuel cut the engine spins down for a second or so before stopping. So the Guino would read fuel use till the engine stops spinning at which time the computer stops firing the injectors via the ground-side circuit. That's when the Guino will recognize full fuel cut. Over a tankful I calculated that might be .04 gal which may or may not be "significant".
To get the Guino to read it properly, I'd need to either follow the notes to kill the input from those 2 sensors to the pcm - OR - cut the 12V injector power and at the same time, cut the injector signal to the Guino. That would require a 2nd relay running off the dash switch that will control fuel cut. I could handle that.
It's late. Work tomorrow. G'night.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
j12piprius (01-27-2015)
Old 05-23-2010, 11:41 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I would wait till you are bit on the guino speculation If the injectors are not getting power then neither is the guino injector signal.
Old 05-24-2010, 06:21 PM   #14 (permalink)
Hyperlurker
daring4's Avatar
Brucepick I think the guino will stop seeing fuel use as soon as the signal to injectors is lost, regardless of engine rotation. When I flip my switch it goes to 999mpg instantly, and I have tried killing the injectors with the throttle pinned to keep the engine spinning...same result 999mpg. Doesn't coast very good that way FYI!
Old 05-24-2010, 07:24 PM   #15 (permalink)
brucepick's Avatar
Gen-1 Insights
dcb,
I'm sorry I don't get what you're saying about "wait till you are bit on the guino speculation". I'm sure I'm just being obtuse but hmmm??
BTW I do have the guino pretty well calibrated. Did distance with a GPS. Fuel qty is good enough now that a 9.4 gal fillup was only off by about .05 gal. I put in the correcion for that so hopefully next fillup will be even closer.
Old 05-24-2010, 07:42 PM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
you are saying that the guino will keep tracking after the injectors are cut? that is the part I thought was speculation as it didn't make sense to me. If you are still getting a reading then they are probably still firing.
.05 gal out of 10 is better than a pointed stick in the eye
Old 05-24-2010, 09:51 PM   #17 (permalink)
brucepick's Avatar
Gen-1 Insights
OK I follow.
We'll see once it gets hooked up. Spent the evening doing the interior part of the project - lead from the engine bay and powered + wire hooked up to dash switch. Later for the engine bay side with relay.
Old 05-26-2010, 07:40 PM   #18 (permalink)
brucepick's Avatar
Gen-1 Insights
OK, it's hooked up and working smoothly.
The only issue is, when I kill the engine that way the computer behaves as if I'd keyed off the engine - in that it refuses to allow lean burn until driving exactly 2 miles with engine running. Unfortunately I'm not sure exactly where in the circuit I made the cut; only that it does kill the injector 12V power before it gets to the injectors.
Next time I work on it I could try the CKP and CYP sensors that dcb and Christ mentioned.
Old 05-27-2010, 09:58 AM   #19 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Great! That should work just fine for me, since I have no lean burn.
Old 05-27-2010, 10:09 AM   #20 (permalink)
dcb
needs more cowbell
dcb's Avatar
@bruce, are you able to tell when in lean burn with the guino? by watching mpg or gph or something?
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
95 Civic EX - Too much power abshnasko EcoModding Central 16 03-01-2011 11:19 AM
Diesel Power Magazine Disappointment. ConnClark EcoModding Central 16 06-05-2009 10:39 PM
Removed '00 Civic power steering belt and got good results but... hondaworkshop EcoModding Central 8 10-07-2008 01:23 PM
