Old 07-01-2010, 11:20 AM   #35 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Not a bad idea, but I imagine that is there for cooling. If I use it for a turbine, I'm not only stealing that cooling capacity, I'm heating it up! I imagine that ending in a bad way.
Almost none at this point. Most exhausts are stainless so IMO its not a huge deal. Of course heat transfer through SS is pretty bad, so that is a concern.
I don't know where I'd place it yet. Obviously the closer to the engine the more available power and less need to insulate the exhaust. In the environmental aspect of it, you'd not want to rob heat from the CAT though.
i was meaning extend the shaft, than put another one on, and drive that?that way original one still cools the alt?
Could you not route a pipe inside the exhaust to heat the water?
I see what you say about the cat, just depends how much water you want to heat?
