Old 07-08-2010, 02:30 PM   #7 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Originally Posted by bestclimb View Post
Alternately you can check it at the back of the cluster by following the trace on the back that goes from one of the three speedometer screws not labled + or - to the plug and tapping into that wire. Might as well leave leave a long wire attached to the signal wire where you can get to it because you will be needing it if you want to install an MPGuino.
The plus side of leaving a tap into the signal wire is that you can monitor it while the speedo is not working to verify you have a good signal even when the speedo is jumping around and/or showing 0.
An excellent idea; thanks bestclimb! I'll tackle that this weekend.
