Old 08-10-2010, 02:47 AM   #8 (permalink)
Clev
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Originally Posted by Nigel2112 View Post
Basically I'm hoping to convert a Honda PC800. My minimum range requirements are to take in certain locations the metro Atlanta area, within reason. I don't want a 25 mile city-bike! Perhaps I need to scale my expectations down? I'm not sure.
The other idea was to start with the bike and then go to the generator trailer idea - which I absolutely love.
I LOVED my PC800, and think it would make a great conversion.
What's your budget? You'll have a lighter, faster bike with longer range if you use Lithium, but you'll spend more on the batteries, charger and BMS.
Here's my basic thought for how I would do a PC800 if I had the means:
1. Connect the motor direct-drive to the driveshaft; toss the transmission.
2. Remove the fuel tank and use that space as a glove compartment, or install the charger in that space and use the filler door to lock your charger cable in while charging. (You'll have to notch the door.)
3. It's generally accepted on the EV list that 500 pounds of lead is equivalent to a gallon of gas. Therefore, if you want 35 or 40 miles on a charge, you're looking at about 500 pounds of lead. Lithium will get you further with less weight.
4. Some other places you can put stuff: DC/DC and contactors behind the instrument panel or where the coolant filler is now, hollow out your exhaust shrouds and use them to store your charger cords, keep the motor low in the chassis and fill the space above with batteries.
Oh yeah, and make sure you start a build log so I can live vicariously!
